Mapscript adding class with PHP
Arie Mijnlieff mijnlief at XS4ALL.NL
Wed Oct 4 15:49:34 EDT 2006
Bart !
That clearifies a lot. I didn't know i could save the mapfile.
The problem was that my new class was the last one in the layer. It
was after:
CLASS
       NAME "Other Countries"
       EXPRESSION ('[NAME]' ne 'Canada')
       METADATA
       END
       STYLE
         ANGLE 360
           COLOR 200 200 200
           OUTLINECOLOR 100 100 100
         SYMBOL 0
       END
       STYLE
         ANGLE 360
           COLOR 100 100 100
           OUTLINECOLOR 255 255 255
         SYMBOL 0
       END
     END
So i added in php:
$this_layer->moveclassup(2);
Then i changed the expression of the Other Countries Class
$myclass = $this_layer->getClass(2);
$myclass->setExpression("(('[NAME]' ne 'Canada') AND ('[NAME]' ne
'Chad'))");
That was it. Thanks a lot !
Arie
On 4-okt-2006, at 11:25, Eijnden, Bart van den (AGI) wrote:
> Arie,
> can you save your MAP using
> $map->save('<filename>');
> And post the output LAYER definition?
> Also, have you set CLASSITEM on your LAYER?
> Best regards,
> Bart
> -----Oorspronkelijk bericht-----
> Van: Arie Mijnlieff [mailto:mijnlief at xs4all.nl]
> Verzonden: woensdag 4 oktober 2006 11:03
> Aan: Eijnden, Bart van den (AGI)
> CC: MAPSERVER-USERS at LISTS.UMN.EDU
> Onderwerp: Re: [UMN_MAPSERVER-USERS] Mapscript adding class with PHP
> Bart !
> My code is now:
> $this_layer = $map->getLayerByName('countries');
> $new_class = ms_newClassObj($this_layer);
> $new_class->setExpression('Russia');
> $new_class->set('name','Russia');
> $new_class->label->outlinecolor->setRGB(255,255,255);
> $new_class->label->set(minfeaturesize,40);
> $new_style = ms_newStyleObj($new_class);
> $new_style->color->setRGB(100,100,100);
> $new_style->outlinecolor->setRGB(255,255,255);
> $img=$map->draw();
> $img->saveImage("/var/www/html/mapdemo/images/test.jpg");
> Doesnt work however..
> I really appreciate your help !
> Arie
> On 4-okt-2006, at 10:06, Eijnden, Bart van den (AGI) wrote:
>> Arie,
>> you can best use a style object. Example:
>>     $oClass = ms_newClassObj($oLayer);
>>     $oStyle = ms_newStyleObj($oClass);
>>     $aColor[0] = 0;
>>     $aColor[1] = 0;
>>     $aColor[2] = 0;
>>     if ($HTTP_FORM_VARS["COLOR"]!= "")
>>       $aColor = explode(",", $HTTP_FORM_VARS["COLOR"]);
>>     $oStyle->color->setRGB($aColor[0], $aColor[1], $aColor[2]);
>> Best regards,
>> Bart
>> Van: UMN MapServer Users List
>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Arie Mijnlieff
>> Verzonden: woensdag 4 oktober 2006 10:06
>> Aan: MAPSERVER-USERS at LISTS.UMN.EDU
>> Hi Murat !
>> No this doesnt solve the problem:
>> PHP Fatal error:  Call to a member function on a non-object in /var/
>> www/html/mapdemo/bulgaria/test.php on line 13
>> color is not an attribute of the class object.. Maybe i should try to
>> define a new layer with php for each country that i would like to
>> paint..
>> Thanks for your suggestion !
>> Arie
>> On 4-okt-2006, at 8:38, Murat BEYHAN wrote:
>>> Hi Arie,
>>> please try the following in yor php script,
>>> I'm new on PhpMapscript so. I hope this solve your problem
>>>> $new_class->setExpression('Australia');
>>>> $new_class->set('name','Australia');
>>>   $new_class->color->setRGB(255,0,0);////////////////here you
>>> should add
>>> regards
>>> Murat
>>> On Tue, 3 Oct 2006 21:35:33 +0200, Arie Mijnlieff wrote
>>>> Hi,
>>>> I want to show countries in my world map based on a form with
>>>> checkboxes.
>>>> If I check Argentina and Australia i would like to show both
>>>> countries in red, whereas the other are in another color. If i
>>>> change  the selection in Australia and India i would like Australia
>>>> and India  to be red.
>>>> I have a .map file with a layer called countries. In that layer i
>>>> have a class:
>>>>     CLASS                   # Start of CLASS object
>>>>        NAME 'Argentina'
>>>>        EXPRESSION 'Argentina'
>>>> 	  COLOR 255 255 150
>>>>        LABEL
>>>> 	   SIZE LARGE
>>>> 	   MINFEATURESIZE 40
>>>>        END
>>>>      END                     # End of CLASS object
>>>> So i thought if Australia is checked, i add a class object to my
>>>> layer using php with the same colors:
>>>> Australia will not be red however. I do not understand how i can
>>>> change the color of my new class. I succeeded only to change the
>>>> color of the label.. What do i do wrong ?
>>>> If i change the color of an existing class i can see that change
>>>> however..
>>>> $my_class = $this_layer->getClass(0);
>>>> $my_class->setExpression('Australia');
>>>> $my_class->set('name','Australia');
>>>> Any help will be appreciated !!
>>>> Arie
>>>> This message has been scanned for viruses and
>>>> dangerous content by MailScanner, and is
>>>> believed to be clean.
>>> Open WebMail Project (http://openwebmail.org)
>> Disclaimer
>> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
>> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per
>> abuis
>> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
>> informeren. Wij adviseren u om bij twijfel over de juistheid of de
>> volledigheid van de mail contact met afzender op te nemen.
>> This message shall not constitute any rights or obligations.
>> This message is intended solely for the addressee.
>> If you have received this message in error, please delete it and
>> notify the sender immediately. When in doubt whether this message
>> is correct or complete, please contact the sender.
> Disclaimer
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
