S57 Soundings Value
Frank Warmerdam
warmerdam at POBOX.COM
Sat Oct 7 01:54:13 EDT 2006
Stephane Lessard wrote:
> Sorry about the double-post... I forgot to change the subject...
> Hello List,
> I'm trying to display the S57 Soundings values on my map. Here's the output
> of ogrinfo on the SOUNDG layer of my S57 chart (the relevant part, for 1
> feature):
> OGRFeature(SOUNDG):140
> RCID (Integer) = 141
> MULTIPOINT (-72.373733104642483 46.402858362124853 9.5)
> I can display a SYMBOL at the appropriate coordinate, but what I need is the
> actual Z value... (9.5) Anyone can help me accomplish this? What should I
> put as a LABELITEM? Here is my layer definition:
Stephane,
Normally this would not be possible. But it happens that others have had
a similar wish with the S57 driver before, and so there are some special
hacks (aka runtime options) that make this possible.
You can set the OGR_S57_OPTIONS variable to include
SPLIT_MULTIPOINT=ON,ADD_SOUNDG_DEPTH=ON and then the multipoints
will be split up with one feature per sounding, and a new DEPTH attribute
with the depth value.
eg.
ogrinfo --config OGR_S57_OPTIONS SPLIT_MULTIPOINT=ON,ADD_SOUNDG_DEPTH=ON -ro
GB4X0000.000 SOUNDG
In the mapfile, this can be accomplished with the CONFIG keyword at
the map level.
eg.
CONFIG "OGR_S57_OPTIONS" "SPLIT_MULTIPOINT=ON,ADD_SOUNDG_DEPTH=ON"
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
