FW: simple question that the answers eludes my logic
Dan Dansereau ddansereau at HYDROPOINT.COM
Mon Oct 9 20:27:11 EDT 2006
Hello ALL
I have a need to have a small map file ( at the bottom of this email )
and a CGI driver - based on the Itasca Demo - it works for me,
and do to the total amount of other processes and scripts that make
use if this technique - a rewrite to another form such as PHP or JAVA
is currently out of the question.
I would like to have the map file get the raster image name at run time
And not fixed with "Jan" like the below map file segment. I'm not sure
where
or how to put this in the HTML. Currently the HTML gets then names from
a
pre-defined pull down menu. The new names need to be similar to
Jan_01_2006
but can be anything legal date range.
LAYER
  NAME Jan_Earth
  TYPE RASTER
  STATUS ON
  TILEINDEX "Jan_index.shp"
  TILEITEM "Location"
  CLASS
    NAME 'Jan_Earth'
    keyimage data/JanKey.png
  END
END
I have tried several different ways as per the documentation to insert
this into the html and the map file
but with no success.
Would anybody have a mapfile and a CGI example that would be somewhat
compatible that they would be willing to share - or be able to point me
towards some additional documentation...
My thanks ahead of time...
Dan
This is the map file
# start of maps file
MAP
NAME WORLD
STATUS ON
SIZE 600 600
EXTENT -180.0 -90.0 180.0 90.0
UNITS dd
SHAPEPATH "data"
IMAGECOLOR 255 255 255
TEMPLATEPATTERN "world"
IMAGETYPE PNG
SYMBOL
  NAME 'circle'
  TYPE ELLIPSE
  POINTS 1 1 END
  FILLED TRUE
END
......took a bunch out here due to the 80k email limits
# Start of layer definitions
# raster data 1st
# World Images by Month
LAYER
  NAME Jan_Earth
  TYPE RASTER
  STATUS ON
  TILEITEM "Location"
  CLASS
    NAME 'Jan_Earth'
  END
END
LAYER
  NAME Feb_Earth
  TYPE RASTER
  STATUS ON
  TILEINDEX "Feb_index.shp"
  TILEITEM "Location"
  CLASS
    NAME 'Feb_Earth'
    keyimage data/FebKey.png
  END
END
# then the rest of the maps
LAYER
  CONNECTIONTYPE postgis
  CONNECTION "user=dad dbname=maps host=10.0.0.215"
  NAME wld_country
  TYPE POLYGON
  DATA "the_geom from wld_country"
  STATUS on
  TRANSPARENCY 50
  CLASS
    NAME 'wld_country'
    OUTLINECOLOR 1 1 1
  END
END
.........took a bunch out here due to the 80k email limit
END # Map File
This is the html file
<html>
<head>
<meta http-equiv="Content-Language" content="en-us">
<title>MapServer/Imaps</title>
<! all code and source from the mapserver examples and documentation ->
<!-- the DHTML JavaScript library includes -->
<script language="javascript" src="javascript/cbe/cbe_core.js"></script>
src="javascript/cbe/cbe_event.js"></script>
<!-- MapServer specific JavaScript library includes -->
<script language="javascript" src="javascript/mapserv.js"></script>
<script language="Javascript" src="javascript/dbox.js"></script>
<!-- utility library -->
<script language="JavaScript" src="javascript/utils.js"></script>
<!-- scripting specific to the application -->
<script language="javascript">
  // first, nab any arguments passed to this page (so we don't have to
edit the page)
  var args = getargs();
  // the DHTML main mapping window
  var main = new dBox("main", 600, 600, "#FF0000", 2);
  // main.verbose = true;
  // the DHTML reference map window
  var reference = new dBox("reference", 120, 120, "#989898", 1);
  reference.box = false;
  reference.cursorsize = 0;
  // mapserv.js global variables
  var MapServer = args.program;
  var QueryServer = MapServer;
  var Interface = "dhtml";
  // create the Mapserv object
  var ms = new Mapserv("main", args.map, -180.0, -90.0, 180.0, 90.0,
600, 600);
  // layer definitions
  ms.layers[ms.layers.length] = new Layer('wld_country', 'wld_country',
'layers', true, null, null);
  ms.layers[ms.layers.length] = new Layer('Jan_Earth', 'Jan_Earth',
'layers', false, null, null);
  ms.layers[ms.layers.length] = new Layer('Feb_Earth', 'Feb_Earth',
  ms.layers[ms.layers.length] = new Layer('wld_states', 'wld_states',
  ms.layers[ms.layers.length] = new Layer('stations', 'stations',
  ms.buildlayers();
  // add the reference map
  ms.referencemap = new Mapserv("reference", args.map, -180.0, -90.0,
180.0, 90.0, 180, 180);
  // Extensions to Mapserv.draw(): this allows you to exend the
capabilties of
  // of the default draw method. There are post and pre draw functions
available.
  function predraw() {
    // clear any query results
    top.query_frame.location.href='blank.html';
....this is most of the standard java pan/zoom/scalebar stuff
  // various event handlers called by jBox/dBox
  function mousemove_handler(name, x, y) {
    window.status = "Coordinates: x=" + Math.round(Number(ms.extent[0] +
x*ms.cellsize)) + " and y=" + Math.round(Number(ms.extent[3] -
y*ms.cellsize));
  function mouseexit_handler(name) { window.status = ""; }
  function mouseenter_handler(name) { window.status = ""; }
  // page initialization function
  function windowOnload() {
    main.initialize();
    reference.initialize();
    ms.zoomdir=1;
    ms.draw();
  // zoom to full extent function
  function ZoomExtent() {
    main.initialize();
    ms.zoomdir=1;
    ms.draw();
</script>
</head>
<body bgcolor=#FFFFFF onResize="main.sync();reference.sync()">
<center>
<table border=0 cellspacing=0 cellpadding=4>
<tr>
<td valign="top" align=center>
  <div align="center">
  <table width="390" border="0" cellspacing="0" cellpadding="0"
bgcolor="#000080">
    <tr>
      <td align="right" width="18"><a
href="javascript:ms.pan('nw')"><img src="graphics/nw.gif" width="18"
height="18" border="0" alt="pan northwest"></a></td>
...this was the pan and map html stuff....
<td valign="top" bgcolor=#ffffff>
  <table cellpadding="1" cellspacing="0" border="0" bgcolor="#ffffff">
    <tr><td>
    <form name="mapserv" action="javascript:void(0)">
      &nbsp;<img border="0" src="wtcc.png" width="195" height="58"><br>
                <hr color="#3399FF">
        <b>&nbsp;World Base Map </b>
                <br>
                <b>&nbsp;Choose an Action: </b><br>
        <input onClick="ms.mode='map'" type="radio" name="mode" checked>
Browse Map<br>
        <input onClick="ms.mode='nquery'" type="radio" name="mode">
Query Features
        <br>
        <b>Select Map Layers to Display </b><br>
        <select multiple name="layers" size=4
onChange="ms.togglelayers(this)">
          <option value="Jan_Earth" >Jan Earth Image
          <option value="Feb_Earth" >Feb Earth Image
         <option value="wld_country" selected > Country Boundaries
         </option>
        </select><br>
        <input type="button" value="Refresh Map" onClick="ms.draw()">
        <input type="button" value="Zoom Full" onClick="ZoomExtent()">
        <b>Zoom Controls - Select &amp; Click on Map</b><br>
        Zoom In <input onClick="ms.zoomdir=1" type=radio name=zoomdir >
        Pan <input onClick="ms.zoomdir=0" type=radio name=zoomdir
checked>
        Zoom Out <input onClick="ms.zoomdir=-1" type=radio name=zoomdir>
        <br>
        <font size="1">Zoom in by drawing a "rubber band" box (left
button on
                the mouse)</font>
      </form>
      <b>Legend:</b><br>
      <img name="legend" src="graphics/red_pixel.gif">
      <br>
      <!-- this is the holding spot (the anchor) for the reference map
      <DIV id="reference_anchor" style="position:relative;
visibility:visible; width:100%; height:100%; left:0px; top:0px;">
      <img src="graphics/red_pixel.gif" height="180" width="180"></DIV>
      <!-- absolutely positioned layer to hold the reference map -->
      <DIV id="reference" style="position:absolute; visibility:visible;
width:100%; height:100%; clip:rect(100%,100%,100%,100%);
background:transparent;">
      <IMG name="reference" src="data/world.png" height="180"
width="180"></DIV>
    </td></tr></table>
  </td></tr>
</table>
</center>
<p>
<a href="javascript:top.location.href='wx_map1.html'">Return to Weather
Station & Interactive Selection</a> from
  document.write("<b>" + args.map_web_template + "</b>");
</script>
</body></html>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061009/e4f07e4a/attachment.html
