Adding points to a shp file
mikiet
mike.talbutt at DOTTEDEYES.COM
Tue Oct 10 07:13:41 EDT 2006
Hi there,
I am using java mapscript and have a requirement to add some points to an
ESRI shape file (bear with me here, I'm a mapinfo man). I'm using an ESRI
shape file that came with the ms101 tutorial WorldCities.shp. Its definitly
a point shape file as when I run ogrinfo on it I get
Layer name: worldCities
Geometry: Point
Feature Count: 0
Extent: (0.000000, 0.000000) - (0.000000, 0.000000)
Layer SRS WKT:
(unknown)
ATTRIB: Integer (4.0)
MGCC: Integer (4.0)
ADMIN_CODE: Integer (4.0)
UFI: Integer (9.0)
POPULATION: Integer (9.0)
I have created a simple class to add a point to this file, see below, the
code runs without error however no feature is added to the file, I'm sure
its a simple fix but can anyone point me in the right direction please ?
public static void test(){
try {
System.out.println("starting run....");
shapeObj shape = new shapeObj(mapscript.MS_SHAPEFILE_POINT);
lineObj lo = new lineObj();
pointObj po = new pointObj(1d,1d,0d);
lo.add(po);
shape.add(lo);
String shapeFullPath =
"C:\\ms4w\\apps\\ms101\\data\\shapefile\\WorldCities.shp";
shapefileObj shapefile = new shapefileObj(shapeFullPath,
shapefile.add(shape);
System.out.println("Shape added");
} catch (Exception e) {
e.printStackTrace();
View this message in context: http://www.nabble.com/Adding-points-to-a-shp-file-tf2415928.html#a6734343
Sent from the Mapserver - User mailing list archive at Nabble.com.
