Adding points to a shp file
Trimble, Beheen
btrimble at SFWMD.GOV
Tue Oct 10 08:57:16 EDT 2006
I don't know mapscript but below does not look right to me:
lineObj lo = new lineObj();
pointObj po = new pointObj(1d,1d,0d);
lo.add(po);
Are you adding a point object to a line object consisting of only one
point?
If that is how line is created in java mapscript I think it should be 2
points.
Try just adding the point to shape object by itself, just create on type
shape object such as point shape.
B
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of mikiet
Sent: Tuesday, October 10, 2006 8:48 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Adding points to a shp file
I've noticed that the first time I ran my test it emptied the shape
file, the
original ogrinfo on the file produced was
Layer name: worldCities
Geometry: Point
Feature Count: 12686
Extent: (-178.166667, -54.800000) - (179.383333, 78.933333)
Layer SRS WKT:
(unknown)
ATTRIB: Integer (4.0)
MGCC: Integer (4.0)
ADMIN_CODE: Integer (4.0)
UFI: Integer (9.0)
POPULATION: Integer (9.0)
after I had run my test the features were 0 and the extents 0.
the point coordinate that I am adding (1,1) in the test is well within
the
extents of the original shape file (-178.166667, -54.800000) -
(179.383333,
78.933333)
Trimble, Beheen wrote:
> What is the coordinate of your new points? Are you adding (1,1,0)? Is
> the unit understood by ogr? The problem usually is among extent,
> projection and spatial reference! See if mapscript has any of these
> types of functions. The extent shown, below, by grinfo is not
promising.
> B
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu]
On
> Behalf Of mikiet
> Sent: Tuesday, October 10, 2006 7:14 AM
> To: MAPSERVER-USERS at lists.umn.edu
> Subject: [UMN_MAPSERVER-USERS] Adding points to a shp file
> Hi there,
> I am using java mapscript and have a requirement to add some points to
> an
> ESRI shape file (bear with me here, I'm a mapinfo man). I'm using an
> ESRI
> shape file that came with the ms101 tutorial WorldCities.shp. Its
> definitly
> a point shape file as when I run ogrinfo on it I get
> Geometry: Point
> Feature Count: 0
> Extent: (0.000000, 0.000000) - (0.000000, 0.000000)
> Layer SRS WKT:
> (unknown)
> MGCC: Integer (4.0)
> UFI: Integer (9.0)
> I have created a simple class to add a point to this file, see below,
> the
> code runs without error however no feature is added to the file, I'm
> sure
> its a simple fix but can anyone point me in the right direction please
> public static void test(){
> try {
> System.out.println("starting run....");
> shapeObj shape = new
> shapeObj(mapscript.MS_SHAPEFILE_POINT);
> lo.add(po);
> shape.add(lo);
> String shapeFullPath =
> "C:\\ms4w\\apps\\ms101\\data\\shapefile\\WorldCities.shp";
> shapefileObj shapefile = new shapefileObj(shapeFullPath,
> shapefile.add(shape);
> System.out.println("Shape added");
> } catch (Exception e) {
> e.printStackTrace();
http://www.nabble.com/Adding-points-to-a-shp-file-tf2415928.html#a673434
> 3
> Sent from the Mapserver - User mailing list archive at Nabble.com.
http://www.nabble.com/Adding-points-to-a-shp-file-tf2415928.html#a673566
4
