HTML Legend - Class count
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Oct 10 11:31:01 EDT 2006
I was thinking the same thing last week. I checked the source and this
option is
not available although it should be. I had to work around it by setting
a metadata
element like * multiclass 'true'. However, the code should be able to
figure that
out itself. (Note I may have missed something so if the DMSolutions
guys want
to chime in...)
Probably should file a feature request in bugzilla.
Steve
>>> "Pleyer, Walter" <Walter.Pleyer at LFRZ.AT> 10/10/2006 9:29:12 AM >>>
Hi Folks!
I'm trying to develop a flexible HTML-Template for a legend and I want
ti treat layers with only class different from layers with multiple
classes.
Is there a possibility in the Template to determine if a layer has 1
or
more classes and use that for a condition?
cheers
Walter
LFRZ
A-1200 Wien, Dresdner Strasse 89
Tel: ++43(1)33 176/421
Fax: ++43(1)33 176/999
Mobil: 0676/5256642
Email: walter.pleyer at lfrz.at
WWW: http://www.lfrz.at
