Adding points to a shp file
Trimble, Beheen btrimble at SFWMD.GOV
Tue Oct 10 11:53:23 EDT 2006
I looking at this constructor:
shapefileObj(char *filename, char *shapepath, int type)
Perhapse yours is another constructor. See if you can find what are the
permissible values for the type. Maybe one is new, one is insert, one is
update? I am just gussing!
Also see if you can use any of these on your object to get more
information of what is going on with the new shapefileObj!
B
shapefileObj.isopen
shapefileObj.lastshape
shapefileObj.source
shapefileObj.status
shapefileObj.statusbounds
shapefileObj.addPoint(pointObj)
shapefileObj.getExtent(int, rectObj)
shapefileObj.getPoint(int, pointObj)
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of mikiet
Sent: Tuesday, October 10, 2006 11:40 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Adding points to a shp file
I've made some progress
the reason my shape file had 0 features after I ran my test was because
it
was recreating the shape file,
I changed the code from
shapefileObj shapefile = new shapefileObj(shapeFullPath,
mapscript.MS_SHAPEFILE_POINT);
to
shapefileObj shapefile = new shapefileObj(shapeFullPath, -2);
and the shp file is not recreated, looking at the modified date it is
actuall modified, however when I run ogrinfo on my layer the feature
count
has not gone up, also when I view the layer using OpenEV my new point
has
not been added. Also still not seeing any error messages, can anyone
help
please ?
Trimble, Beheen wrote:
> Are you using a mapfile to display the point? Can you look at the new
> shape in arccatalog? Can you see the attribute of the point in its
> table?
> B
> From: Mike Talbutt [mailto:mike.talbutt at dottedeyes.com]
> Sent: Tuesday, October 10, 2006 9:03 AM
> To: Trimble, Beheen; MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: RE: [UMN_MAPSERVER-USERS] Adding points to a shp file
> Unfortunately in the java mapscript API the add method on shape only
> takes a lineObj object, I believe a lineObj with only one point set is
a
> point.
> From: Trimble, Beheen [mailto:btrimble at sfwmd.gov]
> Sent: 10 October 2006 13:57
> To: Mike Talbutt; MAPSERVER-USERS at LISTS.UMN.EDU
> I don't know mapscript but below does not look right to me:
> lineObj lo = new lineObj();
> pointObj po = new pointObj(1d,1d,0d);
> lo.add(po);
> Are you adding a point object to a line object consisting of only one
> point? If that is how line is created in java mapscript I think it
> should be 2 points. Try just adding the point to shape object by
itself,
> just create on type shape object such as point shape.
> B
On
> Behalf Of mikiet
> Sent: Tuesday, October 10, 2006 8:48 AM
> I've noticed that the first time I ran my test it emptied the shape
> file, the original ogrinfo on the file produced was
> Layer name: worldCities
> Geometry: Point
> Feature Count: 12686
> Extent: (-178.166667, -54.800000) - (179.383333, 78.933333) Layer SRS
> WKT:
> (unknown)
> ATTRIB: Integer (4.0)
> MGCC: Integer (4.0)
> ADMIN_CODE: Integer (4.0)
> UFI: Integer (9.0)
> POPULATION: Integer (9.0)
> after I had run my test the features were 0 and the extents 0.
> the point coordinate that I am adding (1,1) in the test is well within
> the extents of the original shape file  (-178.166667, -54.800000) -
> (179.383333,
> 78.933333)
>> What is the coordinate of your new points? Are you adding (1,1,0)? Is
>> the unit understood by ogr? The problem usually is among extent,
>> projection and spatial reference! See if mapscript has any of these
>> types of functions. The extent shown, below, by grinfo is not
> promising.
>> B
>> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu]
> On
>> Behalf Of mikiet
>> Sent: Tuesday, October 10, 2006 7:14 AM
>> To: MAPSERVER-USERS at lists.umn.edu
>> Subject: [UMN_MAPSERVER-USERS] Adding points to a shp file
>> Hi there,
>> I am using java mapscript and have a requirement to add some points
to
>> an ESRI shape file (bear with me here, I'm a mapinfo man). I'm using
>> an ESRI
>> shape file that came with the ms101 tutorial WorldCities.shp. Its
>> definitly
>> a point shape file as when I run ogrinfo on it I get
>> Geometry: Point
>> Feature Count: 0
>> Extent: (0.000000, 0.000000) - (0.000000, 0.000000)
>> Layer SRS WKT:
>> (unknown)
>> MGCC: Integer (4.0)
>> UFI: Integer (9.0)
>> I have created a simple class to add a point to this file, see below,
>> the code runs without error however no feature is added to the file,
>> I'm sure
>> its a simple fix but can anyone point me in the right direction
please
>>     public static void test(){
>>    	 try {
>>    		System.out.println("starting run....");
>> 		shapeObj shape = new
> shapeObj(mapscript.MS_SHAPEFILE_POINT);
>> 		lo.add(po);
>> 		shape.add(lo);
>> 		String shapeFullPath =
>> "C:\\ms4w\\apps\\ms101\\data\\shapefile\\WorldCities.shp";
>> 		shapefile.add(shape);
>> 		System.out.println("Shape added");
>>     } catch (Exception e) {
>>     	e.printStackTrace();
>> View this message in context:
http://www.nabble.com/Adding-points-to-a-shp-file-tf2415928.html#a673434
>> 3
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
http://www.nabble.com/Adding-points-to-a-shp-file-tf2415928.html#a673566
> 4
> Email has been scanned for viruses and spam by Altman Technologies'
> email management service - www.altman.co.uk/emailsystems
http://www.nabble.com/Adding-points-to-a-shp-file-tf2415928.html#a673911
8
