Virtual layer access OGR ODBC problem
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue Oct 10 15:08:10 EDT 2006
Frank Warmerdam wrote:
> Yewondwossen Assefa wrote:
>> Hi There,
>> I am trying to access an ODBC database using the ogr virtual layer
>> access (using shp2img). The layer seems to be defined properly as far
>> as I know. It looks something like :
>> CONNECTION "<OGRVRTDataSource>
>> <OGRVRTLayer name='AL05AK0001'>
>> <SrcDataSource>ODBC:@sos_test</SrcDataSource>
>> <SrcSQL>SELECT * FROM t_ResEau_Station_Data WHERE Site_Number =
>> 'AL05AK0001'</SrcSQL>
>> <GeometryType>wkbPoint</GeometryType>
>> <LayerSRS>WGS84</LayerSRS>
>> <GeometryField encoding='PointFromColumns' x='Longitude' y='Latitude'/>
>> </OGRVRTLayer>
>> </OGRVRTDataSource>"
>> The error message is the following :
>> msOGRFileNextShape(): OGR error. Attempt to use STRING field
>> `Longitude' with numeric comparison `>'. <br>
>> If I just use the SrcLayer instead of the SrcSQL, It seems to work ok :
>> <SrcLayer>t_ResEau_Station_Data</SrcLayer>
>> From what I understand this occures when comparing the x,y values to
>> the map bbox to see if the element fits in the map. I am using
>> gdal/ogr from CVS (updated few days ago).
> Assefa,
> The problem seems to relate to the VRT (OVF) driver trying to apply
> spatial constraints to the Latitude and Longitude columns. I am
> guessing these fields aren't actually numeric? I'm a bit surprised
> to see that it occurs with SrcSQL, but not with SrcLayer.
> I believe, as a work around, you can set the useSpatialSubquery='FALSE'
> attribute on GeometryField.
> eg.
> <GeometryField encoding='PointFromColumns' useSpatialSubquery='FALSE'
> Best regards,
The useSpatialSubquery='FALSE' seems to do the trick, although I need to
do more tests.
Not sure if the fields are numeric:
* if I do an ogrinfo the Latitude/Longitude is reported as being String
* if I do access the db using php and echo the field types, I get
Latitude DECIMAL and Longitude DECIMAL
I will report if there are other issues.
Thanks.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
