WG: [UMN_MAPSERVER-USERS] HTML Legend - Class count
Maul, Andreas-Alexander Andreas-Alexander.Maul at BGR.DE
Thu Oct 12 05:45:55 EDT 2006
If working on this issue could feature wish 750 also be taken into account?
Regards
Andreas
-----Ursprüngliche Nachricht-----
Von: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Im Auftrag von Steve Lime
Gesendet: Dienstag, 10. Oktober 2006 17:31
An: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: Re: [UMN_MAPSERVER-USERS] HTML Legend - Class count
I was thinking the same thing last week. I checked the source and this
option is
not available although it should be. I had to work around it by setting
a metadata
element like * multiclass 'true'. However, the code should be able to
figure that
out itself. (Note I may have missed something so if the DMSolutions
guys want
to chime in...)
Probably should file a feature request in bugzilla.
Steve
>>> "Pleyer, Walter" <Walter.Pleyer at LFRZ.AT> 10/10/2006 9:29:12 AM >>>
Hi Folks!
I'm trying to develop a flexible HTML-Template for a legend and I want
ti treat layers with only class different from layers with multiple
classes.
Is there a possibility in the Template to determine if a layer has 1
or
more classes and use that for a condition?
cheers
Walter
LFRZ
A-1200 Wien, Dresdner Strasse 89
Tel:   ++43(1)33 176/421
Fax:   ++43(1)33 176/999
Mobil: 0676/5256642
Email: walter.pleyer at lfrz.at
WWW:   http://www.lfrz.at
