Strange OGR VRT Issue
    Pascoe,Tim [Burlington]
    Tim.Pascoe at EC.GC.CA
    Thu Oct 12 10:10:33 PDT 2006
I'm experimenting with placing my OVF file in line, in order to pass in
some variables for a custom WHERE Statement. The first step I took was
changing my OVF file to use the scrSQL tag with a very simple SQL
statement, instead of the srcLayer tag. Both OVF files point to the same
view, in the same database.
New File:
<OGRVRTDataSource>
    <OGRVRTLayer name="CABINPoints">
        <SrcDataSource>ODBC:****/****@CABIN</SrcDataSource>
        <SrcSQL>SELECT * FROM OGRPoints</SrcSQL>
	  <FID>sitedetailsid</FID>
        <GeometryType>wkbPoint</GeometryType>
        <LayerSRS>WGS84</LayerSRS>
    <GeometryField encoding="PointFromColumns" x="longitude"
y="latitude"/>
    </OGRVRTLayer>
</OGRVRTDataSource>
Old FIle:
<OGRVRTDataSource>
        <SrcDataSource>ODBC:****/****@CABIN,OGRPoints</SrcDataSource>
        <SrcLayer>OGRPoints</SrcLayer>
y="latitude"/>
    </OGRVRTLayer>
</OGRVRTDataSource>
The problem is, the old OVF returns a proper image, while the new one
returns a blank image. I ran the new file through OGRInfo and shp2ogr,
and both behave properly.
So........why am I getting a blank image with the scrSQL tag? I'm using
the latest version of the MS4W file set, but running on IIS on Windows
2000. Any suggestions would be great - it's probably somthing very
simple I'm missing :)
Tim Pascoe
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061012/70470527/attachment.htm>
More information about the MapServer-users
