Displaying Mapserver raster in ArcMap gives 256 colours
Eijnden, Bart van den (AGI)
b.vdeijnden at AGI.RWS.MINVENW.NL
Fri Oct 13 05:40:29 EDT 2006
Can you check your Apache log file to see what image format ArcMap is requesting?
Look especially for the &format= part in the WMS GetMap call.
If it will ask for image/png, you might need to enable 24-bit PNG using the following OUTPUTFORMAT in your MAP file:
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE "RGBA"
TRANSPARENT TRUE
END
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens POWER Brendan
Verzonden: vrijdag 13 oktober 2006 11:07
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] Displaying Mapserver raster in ArcMap
gives 256 colours
I have installed ms4w on a windows box with GDAL, etc... From here I
created a sample map (mapfile below) sourcing data from ecw images.
When I use the WMS service via an intranet, I get a full colour image
through the GetMap &LAYER command, however, when using ArcMap, I only
get a 256 colour image. Is there something I am doing wrong?
Any assistance would be appreciated.
NAME TestMap
STATUS ON
SIZE 640 480
EXTENT 116 -24 120 -22
UNITS METERS
SHAPEPATH "d:\Zone_50"
IMAGETYPE FCADIType
OUTPUTFORMAT
NAME FCADIType
DRIVER "GDAL/jpeg"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
FORMATOPTION "INTERLACE=OFF"
FORMATOPTION "QUALITY=100"
FORMATOPTION "OUTPUT_TYPE=RASTER"
END
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp"
IMAGEURL "/ms_tmp/"
LOG "/ms4w/tmp/ms_tmp"
METADATA
"wms_title" "Metro Photosa"
"wms_onlineresource"
"http://pc6-089/cgi-bin/mapserv.exe?map=/ms4w/apache/cgi-bin/test.map"
"wms_srs" "EPSG:4283"
"wms_feature_info_mime_type" "text/html"
"wms_abstract" "Some aerials that I could get easily"
END
END
PROJECTION
"init=epsg:4283"
END
# MAPSHEETS ---------------------------------------
# Mount Lionel Mapsheet
LAYER
NAME mount_lionel_100K
TYPE RASTER
STATUS ON
DATA Mt_Lionel_2452_Aug_2004_Mosaic.ecw
PROJECTION
"init=epsg:28350"
END
METADATA
"wms_title" "Mount_Lionel_100K"
"wms_dataurl_format" "image/jpeg"
"wms_format" "image/jpeg"
END
CLASS
NAME "mount_lionel_100K"
# TEMPLATE
END
END
END # Map File
My apologies for any cross post - last time I tried to send a variation
on this message it bounced...
Brendan Power
Manager GIS
Fire & Emergency Services Authority of WA
address: 480 Hay Street Perth WA 6000
postal: Po Box P1174 Perth WA 6844
phone: 9323 9351 mobile: 0417 918 809
fax: 9323 9384 web: www.fesa.wa.gov.au
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
