How to put labels and change the line width of a map image generated from polyline shapefile
Eijnden, Bart van den (AGI) b.vdeijnden at AGI.RWS.MINVENW.NL
Fri Oct 13 06:41:24 EDT 2006
Yes you can.
Check LABELITEM and LABEL in the MAP file docs on the website.
For line width, check the FAQ:
http://mapserver.gis.umn.edu/docs/faq/linewidth
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Sandeep Kumar Jakkaraju
Verzonden: vrijdag 13 oktober 2006 12:39
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] How to put labels and change the line width of a map image generated from polyline shapefile
How to put labels and change the line width of a map image generated from polyline shapefile ??
I have a roads shapefile ...
Can I label the image with Name of the Roads ..??? and
Can I increase the width of the roads ??
Thanks in advance...
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061013/36f486fb/attachment.html
