labelling please help
Sandeep Kumar Jakkaraju sandeepkumar.jakkaraju at GMAIL.COM
Fri Oct 13 08:15:25 EDT 2006
This the Map file I am using ... i am unable to label it !!
NAME delhimap
STATUS ON
# Map image size. Change size as desired
SIZE 2156 1674
# Start of web interface definition. Only the TEMPLATE parameter
# must be specified to display a map. See Mapserver documentation
WEB
  HEADER Delhi
  TEMPLATE Delhi
  FOOTER Delhi
  MINSCALE 100
  MAXSCALE 10000
# Set IMAGEPATH to the path where mapserver should
# write its output
 IMAGEPATH 'C:/ms4w/apps/test/htdocs/'
# Set IMAGEURL to the url that points to IMAGEPATH
 #IMAGEURL 'C:/ms4w/apps/test/htdocs/'
END
# Extent based on full extent of QGIS view
#EXTENT 77.2018 28.6023 77.2493 28.6382
EXTENT 77.19591 28.6000042 77.25517 28.640461
UNITS meters
#IMAGECOLOR 255 255 255
IMAGECOLOR 0 128 255
IMAGETYPE jpeg
# Projection definition
# Projections are not currenlty supported. If desired, add your own
# projection information based on Mapserver documentation.
LAYER
  NAME "roads_polyline"
  TYPE LINE
  STATUS ON
  DATA "C:/GIS-Data/ESRI Data/roads_polyline"
  LABELANGLEITEM "0"
  LABELCACHE ON
  LABELITEM "id"
  LABELREQUIRES "true"
  LABELMAXSCALE  10014
  LABELMINSCALE  10014
  LABELSIZEITEM  "5"
  CLASS
    NAME "Roads_polyline"
    TEXT "Road"
    # TEMPLATE
    #OUTLINECOLOR 207 150 123
     OUTLINECOLOR 255 255 0
     STYLE
 COLOR 255 255 0
 SYMBOL 'lg'
 SIZE 10
     END
     LABEL
      COLOR 0 0 0
      ANGLE AUTO
      MINSIZE 10
     END
  END
END
SYMBOL
 NAME 'lg'
 TYPE ELLIPSE
 POINTS
  1 1
 END
 STYLE
  10 0 10 0
 END
END
END # Map File
On 10/13/06, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Sandeep Kumar Jakkaraju wrote:
> > I have put the following in my map file
> >   LABELANGLEITEM "0"
> >   LABELCACHE ON
> >   LABELITEM "id"
> >   LABELMAXSCALE  10014
> >   LABELMINSCALE  10014
> >   LABELSIZEITEM  "5"
> > But still i dont see any labels
> > please help !!
> You probably need to post the whole LAYER definition for us to be able
> to help.
WeBlog:
http://jakkarajus.blogspot.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061013/f66467b0/attachment.html
