unable start apache
Sandeep Kumar Jakkaraju sandeepkumar.jakkaraju at GMAIL.COM
Fri Oct 13 12:03:47 EDT 2006
Thanks Daniel
I installed libstdc++ but i am getting this error !!
[root at localhost ~]# fgs start apache
Processing config directory: /opt/fgs/www/conf.d/*.conf
 Processing config file: /opt/fgs/www/conf.d/gdal.conf
 Processing config file: /opt/fgs/www/conf.d/mapserver.conf
 Processing config file: /opt/fgs/www/conf.d/php.conf
Syntax error on line 3 of /opt/fgs/www/conf.d/php.conf:
Cannot load /opt/fgs/www/libexec/libphp4.so into server:
/opt/fgs/www/libexec/libphp4.so: cannot restore segment prot after
reloc: Permission denied
/opt/fgs/etc/init.d/apache start: httpd could not be started
On 10/13/06, Daniel Morissette <dmorissette at mapgears.com> wrote:
> For Fedora Core 5, you'll need to install :
> http://download.fedora.redhat.com/pub/fedora/linux/core/5/i386/os/Fedora/RPMS/compat-libstdc++-33-3.2.3-55.fc5.i386.rpm
> See:
> http://lists.maptools.org/pipermail/foss-gis-suite/2006-April/000380.html
> Daniel
> Sandeep Kumar Jakkaraju wrote:
> > I have download this fgs bin for fedora ...i have installed it in my
> > fedora core 5 ..I am unable to start the apache ...
> > when i do
> > [root at localhost fgs]# fgs start apache
> > Cannot load /opt/fgs/www/libexec/libphp4.so into server: libstdc++.so.5:
> > cannot open shared object file: No such file or directory
WeBlog:
http://jakkarajus.blogspot.com
