installing qgis on fedora core 5
Daniel Morissette dmorissette at MAPGEARS.COM
Fri Oct 13 14:59:21 EDT 2006
FGS is a self-contained environment and the libs that it ships with are
not expected to be compatible with non-FGS packages such as this qgis RPM.
For this RPM to work, you'll need to find the gdal, geos, proj and other
dependencies that it was built for. There must be RPMs for those, but I
just don't see them in a quick browse of the QGIS download site. The
best place to ask for them would be on the QGIS lists I think.
Daniel
Tyler Mitchell wrote:
> I haven't tried this rpm stuff, but be sure to initialise your FGS environment first by running:
> . /opt/fgs/setenv.sh
> Hope that helps,
> Tyler
> ----- Original Message -----
> From: Aaron Racicot <aaronr at Z-PULLEY.COM>
> Date: Friday, October 13, 2006 11:30 am
> Subject: Re: [UMN_MAPSERVER-USERS] installing qgis on fedora core 5
>> Try adding the path to the so's into /etc/ld.so.conf and then running
>> /sbin/ldconfig.  I am not familiar with fgs, but it looks like it is
>> installing the so's into a place that your base system does not
>> know about.
>> A
>> | Aaron Racicot | aaronr at ecotrust.org    |
>> | GIS Programmer | 503.467.0759          |
>> | e c o t r u s t                        |
>> | Jean Vollum Natural Capital Center     |
>> | 721 NW Ninth Avenue                    |
>> | Suite 200                              |
>> | Portland, OR 97209                     |
>> | www.ecotrust.org                       |
>> -----Original Message-----
>> From: UMN MapServer Users List [mailto:MAPSERVER-
>> USERS at LISTS.UMN.EDU] On
>> Behalf Of Sandeep Kumar Jakkaraju
>> Sent: Friday, October 13, 2006 10:45 AM
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: [UMN_MAPSERVER-USERS] installing qgis on fedora core 5
>> I want to install qgis on my fedora core 5 machine...
>> I get this error ....
>> I have fgs already so there is libgdal.so.1 in its lib but the rpm
>> cant find it ...
>> [root at localhost lib]# rpm -i
>> ~/Desktop/qgis_FC4_0.7.4_nopg_nograss.i386.rpm
>> error: Failed dependencies:
>>         libgdal.so.1 is needed by qgis-0.7.4-0.i386
>>         libgeos.so.2 is needed by qgis-0.7.4-0.i386
>>         libgsl.so.0 is needed by qgis-0.7.4-0.i386
>>         libgslcblas.so.0 is needed by qgis-0.7.4-0.i386
>>         libproj.so.0 is needed by qgis-0.7.4-0.i386
>> any help is appreciated..
>> PS:- I know that this is not qgis forum ..but still trying my luck
Daniel Morissette
http://www.mapgears.com/
