WMS STYLES-Parameter and Mapserver 4.10
Eijnden, Bart van den (AGI)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Oct 16 05:31:26 EDT 2006
Hi Arnd,
this is a bug, I had a brief look in the code (mapwmslayer.c) and there was a change which can explain this, see here
http://cvs.gis.umn.edu/cgi-bin/viewcvs/mapserver/mapwmslayer.c.diff?r1=1.78&r2=1.79
Julien or Daniel can probably comment on the fix.
As a workaround you could try:
wms_style "default"
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Arnd Wippermann
Verzonden: maandag 16 oktober 2006 11:11
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] WMS STYLES-Parameter and Mapserver 4.10
Hello,
I have updated to Mapserver 4.10 and now I have the problem, that WMS
Requests deliver white images. The reason is, that Mapserver don't add the
STYLES-Parameter to the request. Is it a bug? I have thought, I add
wms_styles "" to the metadata-section, but this too don't works. To get the
images, i have added "STYLES=&" to the CONNECTION-Parameter in my mapfile
and now I get what I want. Is there a other way to add the parameter to the
request?
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/pinguinale/
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
