c#-mapscript, Rasterlayer in Map?
Christian Wilmes C.Wilmes at GMX.DE
Tue Oct 17 05:56:23 EDT 2006
Hi All,
ist there any possibility to find out, if a Rasterlayer is in the Extent of a Map. There is just one Layer in my Map and I want to know if the map will be blank or the Layer is visible. A possibility is to test each pixel if it is transparent or not, but that is not very effectiv. I thought about first drawing a map with just one 1x1 Pixel, but if the Extent of the Layer is much smaller than the extent of the map the result will be a transparent pixel even the Layer is in the extent of the map.
I tried out the method layerObj.isVisible(), but it doesn't have a look on the extent of the map.
Is there any possibility to find out if a Layer is really visible or just getting the extent of the raster-layer in the Reference-System of the map?
Best Regards
Christian
GMX DSL-Flatrate 0,- Euro* - Überall, wo DSL verfügbar ist!
NEU: Jetzt bis zu 16.000 kBit/s! http://www.gmx.net/de/go/dsl
