csharp querybyattributes
David Lowther dlowther at COORDINATESOLUTIONS.COM
Tue Oct 17 11:59:56 EDT 2006
Tamas,
So here's the weird thing: queryByAttributes gets a resultCache with the
correct number of results and correct extent for all these shapefiles
(county, Garfield, precinct). It highlights for county and precinct, but NOT
Garfield. If I queryByRect all shapefiles highlight. Of course, by highlight
I mean drawQuery shows yellow.
This all leads me to believe there is something about the shapefile causing
the issue. If you still need me to post a sample app or the shapefiles let
me know.
Do you see anything obvious I am missing?
Here's OGRINFO -so for the 3 files:
D:\ms4w\tools\gdal-ogr>ogrinfo -so d:\Data\OKCOUNTY\county.shp county
INFO: Open of `d:\Data\OKCOUNTY\county.shp'
using driver `ESRI Shapefile' successful.
Layer name: county
Geometry: Polygon
Feature Count: 77
Extent: (-103.002647, 33.615765) - (-94.431215, 37.002327)
Layer SRS WKT:
(unknown)
SDSM_ID: Real (11.0)
STATE: Real (11.0)
COUNTY: Real (11.0)
CENTERX: Real (20.6)
CENTERY: Real (20.6)
CO_NAME: String (30.0)
D:\ms4w\tools\gdal-ogr>ogrinfo -so d:\Data\OKCOUNTY\garfield.shp garfield
INFO: Open of `d:\Data\OKCOUNTY\garfield.shp'
Layer name: garfield
Geometry: Polygon
Feature Count: 34333
Extent: (-98.105126, 36.164392) - (-97.460512, 36.593755)
Layer SRS WKT:
(unknown)
LABEL: String (8.0)
ACRES: String (24.0)
MPIN: String (21.0)
PROBLEM: String (12.0)
TOWN_NUM: Real (11.0)
TOWN_DIR: String (1.0)
RANGE_NUM: Real (11.0)
RANGE_DIR: String (1.0)
SECTION: Real (11.0)
PARCEL_NUM: String (25.0)
D:\ms4w\tools\gdal-ogr>ogrinfo -so d:\Data\OKCOUNTY\precinct.shp precinct
INFO: Open of `d:\Data\OKCOUNTY\precinct.shp'
Layer name: precinct
Geometry: Polygon
Feature Count: 2144
Layer SRS WKT:
GEOGCS["GCS_Assumed_Geographic_1",
    DATUM["North_American_Datum_1927",
        SPHEROID["Clarke_1866",6378206.4,294.9786982]],
    PRIMEM["Greenwich",0.0],
    UNIT["Degree",0.0174532925199433]]
AREA: Real (19.5)
PERIMETER: Real (19.5)
ST_FIPS: String (2.0)
CO_FIPS: String (3.0)
COUNTY: String (12.0)
PCT_NUM: String (5.0)
PCT_CEB: String (6.0)
USCONG: String (2.0)
ST_SEN: String (3.0)
ST_HSE: String (3.0)
COMM: String (2.0)
POLLING_PL: String (30.0)
OEB_DATE: String (4.0)
SQMI_AREA: Real (15.5)
EDIT_DATE: String (5.0)
David Lowther
Coordinate Solutions, Inc.
501 N.E. 15th Street
Oklahoma City, OK 73104
405.246.9396 (Voice)
405.227.0781 (Fax)
www.coordinatesolutions.com
-----Original Message-----
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Monday, October 16, 2006 2:31 PM
To: dlowther at coordinatesolutions.com
Cc: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] csharp querybyattributes
I haven't found this kind of behaviour. Are you sure your resultcache
is not empty?
Could you post a sample to reproduce this problem?
Best Regards,
Tamas
2006/10/16, David Lowther <dlowther at coordinatesolutions.com>:
> I'm using mapscript_csharp in vb.net and have noticed a (I think) strange
> behavior.  When using layer.querybyattributes and then map.drawquery no
> features are highlighted, though there are features in the resultcache.
When
> using layer.querybypoint(rect, or shape) map.drawquery does highlight
> features. Is this the intended behaviour?
> Thanks in advance,
> David Lowther
> 405.227.0781 (Fax)
