background dependant line styles ?
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Oct 18 20:52:52 EDT 2006
Sacha,
Look at the REQUIRES option for LAYER.
You would have to create two separate LAYERs and add
REQUIRES "photo_layer"
to one and set it up to draw the green lines and in the other do
something like:
REQUIRES (! "photo_layer")
in the other to draw your normal lines. Where your photo layer has
NAME "photo_layer"
You might have to play with this a little to get it to work, I haven't
tried it, but this would be the concept.
-Steve W
Sacha Black wrote:
> second try. first one bounced.
> sb
> ---------- Forwarded message ----------
> From: *Sacha Black* < sacha.black at gmail.com <mailto:sacha.black at gmail.com>>
> Date: Oct 18, 2006 4:17 PM
> Subject: background dependant line styles ?
> To: MAPSERVER-USERS at lists.umn.edu <mailto:MAPSERVER-USERS at lists.umn.edu>
> is it possible to have two styles for drawing a single line layer, where
> one style is used most of the time and the alternate style is only used
> if a background photo layer is turned on?
> so for example most of the time I want my roads to draw in black, but if
> the photo background is used the roads should draw on top in green.
