4.10.0: Some vectors not rendering for a layer
Ed McNierney
ed at TOPOZONE.COM
Fri Oct 20 07:23:05 EDT 2006
Andre -
You are talking about the d1 and d2 shapefiles, but you're using both DATA and TILEINDEX statements, which seems odd - is each layer supposed to be drawing a single shapefile (DATA "d1") or a group of shapefiles (TILEINDEX "TIGER04/county_index")? It's still early in the morning, but I can't think why it's even allowed to use both in a single LAYER - you should need one or the other.
So as you add "new" vectors, are you editing a single shapefile to add new vectors to it, or are you adding new shapefiles to a TILEINDEX group? If it's the latter, and the new shapefiles don't have the same attribute columns as the older ones, that could cause the problem you're seeing.
I don't understand what "I cleared all the tiles" means.
Could you clear this up and be very specific about the arrangement of the shapefile(s) and tileindex files you're using? Thanks.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Andre Lockhart
Sent: Friday, October 20, 2006 2:43 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] 4.10.0: Some vectors not rendering for a layer
We're still having the problem, so I did some experiments today.
There are 2 shapefiles, d1 & d2. Both have the same coordinates, which follow the contours of the same roadways. We stop them overlapping by defining offsets.
Below is the bit of the mapfile used to render them.
The problem is that only the right offset is displaying for North/South roadways, and only the bottom for East/West roadways. We're only seeing this with recently drawn vectors/segments. Older ones render just fine.
I deleted the d2 layer.
Then I redisplayed the map using the d1 shapefiles (DATA "d1" OFFSET -2 -99). The d1 layer offset to the right for the problem segments.
When I used the d2 shapefiles to render the d1 layer (DATA "d2" OFFSET -2 -99), the offset was to the left for the problem segments. I don't see how this can be possible...how can using a different shapefile somehow override the OFFSET directive for the class?
I cleared all the tiles so that cannot be the problem.
This is really puzzling...any ideas?
LAYER
NAME "direction1-13"
STATUS DEFAULT
DATA "d1"
TYPE LINE
SIZEUNITS PIXELS
# Class: direction 1, Scale 7
CLASS
MINSCALE 100000
MAXSCALE 300000
STYLE
SYMBOL "cartoline"
SIZE 3
COLOR 206 0 0
OFFSET -2 -99
ANTIALIAS true
END
END
END
LAYER
NAME "direction2-14"
STATUS DEFAULT
DATA "d2"
TYPE LINE
SIZEUNITS PIXELS
# Class: direction 2, Scale 7
CLASS
MINSCALE 100000
MAXSCALE 300000
STYLE
SYMBOL "cartoline"
SIZE 3
COLOR 206 0 0
OFFSET 2 -99
ANTIALIAS true
END
END
END
André Lockhart
andre at CoValuate.com
510.333.7189
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Eijnden, Bart van den (AGI)
Sent: Thursday, October 19, 2006 1:16 AM
Subject: Re: 4.10.0: Some vectors not rendering for a layer
The benefit comes with displaying a smaller extent than the full = shapefile, and can be quite large. It's a spatial index (quadtree).
You can generate them using shptree, a utility that comes with Mapserver = (MS4W).
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Andre Lockhart
Verzonden: donderdag 19 oktober 2006 10:14
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] 4.10.0: Some vectors not rendering for a layer
No, we aren't using qix files for these layers.
Also, we are rendering directly from the shapefiles, not via PostGIS or = some other RDBMS.=20
Is there any benefit to qix files? If so, how might one (re)generate = them using open source tools?
Thanks.
=20
=20
Andr=E9 Lockhart
510.333.7189
=20
[mailto:b.vdeijnden at agi.rws.minvenw.nl]=20
Sent: Thursday, October 19, 2006 12:45 AM
To: Andre Lockhart; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] 4.10.0: Some vectors not rendering = for a layer
Are you using a spatial index (qix file)?
If so, did you regenerate the spatial index after the changes?
Best regards,
Bart
Verzonden: donderdag 19 oktober 2006 9:41
Thanks, Andreas.
We've been on 4.10.0 for a few weeks and already have quotes around our expression variables. This problem only appeared after we drew new = vectors for existing shapefiles.
=20
=20
Andr=E9 Lockhart
510.333.7189
=20
From: Andreas Albarello [mailto:andreas.albarello at territoriumonline.com] =
Sent: Thursday, October 19, 2006 12:30 AM
To: Andre Lockhart
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] 4.10.0: Some vectors not rendering = for a layer
Andre Lockhart wrote:
> We have a layer with a few hundred vectors/segments that renders in=20
>different colors based on a class expression. Some of the vectors=20
>render, others do not.
>=20
> We are well under the limit for classes and layers.
>=20
> One clue is that it is the most recently drawn vectors that do not =
render.
>=20
> We've tried rebooting/reinitializing everything, to no avail.
Andre,
I assume everything was working fine with Mapserver prior to version=20 4.10. If that is the case, I suspect you might have run into a problem=20 that I encountered myself with the new release and which I think is=20 related to some changes made in the mapfile lexer.
In particular, I noticed that, when using class expressions of the form
EXPRESSION abcd
(that is a simple string based expression) Mapserver now requires you to =
put quotes around those expressions (i.e. EXPRESSION "abcd") or it=20
*might* fail to recognize them as such. This applies to a layer's FILTER =
as well, but, as with EXPRESSION, only when using string expressions, no =
regular or nested logical expressions (which are still delimited by=20 slashes and brackets, respectively).
Hope this helps.
Best regards,
Andreas
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te=20 informeren. Wij adviseren u om bij twijfel over de juistheid of de=20 volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and notify the sender immediately. When in doubt whether this message is correct or complete, please contact the sender.
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te informeren. Wij adviseren u om bij twijfel over de juistheid of de volledigheid van de mail contact met afzender op te nemen.
