Help with rasters
B Tuttle
funkbucket at GMAIL.COM
Fri Oct 20 13:10:10 EDT 2006
Have you tried the following where TILEINDEX is the name of your index
shapefile and TILEITEM is the name of the field in the index shapefile
that contains the location of the raters?
LAYER
NAME "LayerName"
STATUS ON
TILEINDEX "RasterIndex.shp"
TILEITEM "Location"
TYPE RASTER
END
On 10/20/06, Jeff Dege <jdege at korterra.com> wrote:
> A customer has sent us a bunch of mapdata, to see if we can make any
> sense from it. I've been messing around with mapserver for a while,
> now, and I've figured out how to work some of its capabilities, but this
> is my first attempt to handle rasters.
> The data set has four sets of shape files, three of which are
> point/line/polygon data and the fourth which seems to be a tileindex for
> the thousands of jpg and jgw files.
> I'm starting simple - writing a map file and trying to get a map image
> using shp2img. I have no problem doing this with the three
> point/line/polygon layers. But I've not been able to do this with the
> raster data.
> I can run gdalinfo on the jpg files:
> Driver: JPEG/JPEG JFIF
> Size is 1610, 1609
> Coordinate System is `'
> Origin = (-93.112361,44.933805)
> Pixel Size = (0.00001279,-0.00000900)
> Corner Coordinates:
> Upper Left ( -93.1123608, 44.9338046)
> Lower Left ( -93.1123608, 44.9193245)
> Upper Right ( -93.0917678, 44.9338046)
> Lower Right ( -93.0917678, 44.9193245)
> Center ( -93.1020643, 44.9265646)
> Band 1 Block=1610x1 Type=Byte, ColorInterp=Red
> Band 2 Block=1610x1 Type=Byte, ColorInterp=Green
> Band 3 Block=1610x1 Type=Byte, ColorInterp=Blue
> I can run gdaltindex to create my own tileindex shape file:
> gdaltindex \\server\share\test\data\rasterindex
> And I can run ogrinfo on the generated shapefile:
> INFO: Open of `\\server\share\app\data'
> using driver `ESRI Shapefile' successful.
> Layer name: rasterindex
> Geometry: Polygon
> Feature Count: 683
> Extent: (-93.338884, 44.455961) - (-92.721094, 44.933805)
> Layer SRS WKT:
> (unknown)
> location: String (255.0)
> But when I run shp2img, I get nada. With DEBUG=ON:
> Unable to open file rasterindex for layer A ... ignoring this missing
> data.
> msDrawMap(): Layer 0 (A), 0.000s
> msDrawMap(): Drawing Label Cache, 0.000s
> msDrawMap() total time: 0.000s
> The rastedindex shape files (.dbf, .shp, and .shf) files are in the same
> directories as the other point/line/polygon shape files that I've been
> able to successfully draw layers with using this mapfile. Ogrinfo has
> no trouble accessing the file.
> The underlying .jpg files are in the same directory, and gdalinfo and
> gdaltindex had no trouble opening them.
> The layer in the mapfile itself is pretty simple:
> LAYER
> NAME "A"
> TYPE RASTER
> STATUS ON
> DATA "rasterindex"
> END
> Any hints as to what I'm doing wrong?
