Help with rasters
Bart van den Eijnden (OSGIS) bartvde at OSGIS.NL
Fri Oct 20 13:26:41 EDT 2006
Yep, look especially at creating overviews using gdaladdo.
http://mapserver.gis.umn.edu/docs/howto/raster_data
Btw, jpg is not the best format, tiff would be a better option, but I
guess you can't change that.
Best regards,
Bart
Jeff Dege schreef:
> Yep. That did it. I know have an image of the full extent of the map.
> Only problem is that it took ten minutes to generate.
> Next?  Read up on optimization and tuning of raster maps.
> Thanks for the help.
>> -----Original Message-----
>> From: Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl]
>> Sent: Friday, October 20, 2006 11:49 AM
>> To: Jeff Dege
>> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: Re: [UMN_MAPSERVER-USERS] Help with rasters
>> First of all, change:
>> DATA "rasterindex"
>> into:
>> TILEINDEX "rasterindex"
>> Best regards,
>> Bart
>> Jeff Dege schreef:
>>> A customer has sent us a bunch of mapdata, to see if we can make any
>>> sense from it.  I've been messing around with mapserver for a while,
>>> now, and I've figured out how to work some of its
>> capabilities, but this
>>> is my first attempt to handle rasters.
>>> The data set has four sets of shape files, three of which are
>>> point/line/polygon data and the fourth which seems to be a
>> tileindex for
>>> the thousands of jpg and jgw files.
>>> I'm starting simple - writing a map file and trying to get
>> a map image
>>> using shp2img.  I have no problem doing this with the three
>>> point/line/polygon layers.  But I've not been able to do
>> this with the
>>> raster data.
>>> I can run gdalinfo on the jpg files:
>>>   Driver: JPEG/JPEG JFIF
>>>   Size is 1610, 1609
>>>   Coordinate System is `'
>>>   Origin = (-93.112361,44.933805)
>>>   Pixel Size = (0.00001279,-0.00000900)
>>>   Corner Coordinates:
>>>   Upper Left  ( -93.1123608,  44.9338046)
>>>   Lower Left  ( -93.1123608,  44.9193245)
>>>   Upper Right ( -93.0917678,  44.9338046)
>>>   Lower Right ( -93.0917678,  44.9193245)
>>>   Center      ( -93.1020643,  44.9265646)
>>>   Band 1 Block=1610x1 Type=Byte, ColorInterp=Red
>>>   Band 2 Block=1610x1 Type=Byte, ColorInterp=Green
>>>   Band 3 Block=1610x1 Type=Byte, ColorInterp=Blue
>>> I can run gdaltindex to create my own tileindex shape file:
>>>   gdaltindex  \\server\share\test\data\rasterindex
>>> And I can run ogrinfo on the generated shapefile:
>>>   INFO: Open of `\\server\share\app\data'
>>>   using driver `ESRI Shapefile' successful.
>>>   Layer name: rasterindex
>>>   Geometry: Polygon
>>>   Feature Count: 683
>>>   Extent: (-93.338884, 44.455961) - (-92.721094, 44.933805)
>>>   Layer SRS WKT:
>>>   (unknown)
>>>   location: String (255.0)
>>> But when I run shp2img, I get nada.  With DEBUG=ON:
>>>   Unable to open file rasterindex for layer A ... ignoring
>> this missing
>>> data.
>>>   msDrawMap(): Layer 0 (A), 0.000s
>>>   msDrawMap(): Drawing Label Cache, 0.000s
>>>   msDrawMap() total time: 0.000s
>>> The rastedindex shape files (.dbf, .shp, and .shf) files
>> are in the same
>>> directories as the other point/line/polygon shape files
>> that I've been
>>> able to successfully draw layers with using this mapfile.
>> Ogrinfo has
>>> no trouble accessing the file.
>>> The underlying .jpg files are in the same directory, and
>> gdalinfo and
>>> gdaltindex had no trouble opening them.
>>> The layer in the mapfile itself is pretty simple:
>>>   LAYER
>>>     NAME "A"
>>>     TYPE RASTER
>>>     STATUS ON
>>>     DATA "rasterindex"
>>>   END
>>> Any hints as to what I'm doing wrong?
>> OSGIS, Open Source GIS
>> bartvde at osgis.nl
>> http://www.osgis.nl
bartvde at osgis.nl
http://www.osgis.nl
