Scalebar Rendering Problem
Hong ljfong at SDF.LONESTAR.ORG
Fri Oct 20 15:02:23 EDT 2006
Hello,
I am having trouble where the numbers below the scale bar seems to be
overdrawn rather than redrawn after the map is redrawn. The scale bar is
embedded through C#-MapScript. The output format of my map is PNG with image
mode PC256.
The portion of VB 2005 code I used to embed the scale bar:
Public Sub New()
            m_Position = MS_LABEL_POSITIONS.MS_LL
            m_scaleUnits = MS_UNITS.MS_MILES
            'Actually create and position the scale bar object
            m_scalebarObj = New scalebarObj
            Dim p_labelObj As labelObj = New labelObj
            p_labelObj.type = MS_FONT_TYPE.MS_BITMAP
            p_labelObj.color = New colorObj(0, 0, 0, -4)
            With m_scalebarObj
                .label = p_labelObj
                .backgroundcolor = New colorObj(255, 255, 255, -4)
                .imagecolor = New colorObj(255, 255, 255, -4)
                .intervals = 4
                .postlabelcache = mapscript.MS_TRUE
                .width = 150
                .height = 10
                .status = mapscript.MS_EMBED
                .position = m_Position
                .units = m_scaleUnits
            End With
End Sub
m_scalebarObj is then attached to mapObj through scalebar property.
Here are two screenshots of the scale bar:
http://ljfong.freeshell.org/scalebar_before_map_redraw.png
http://ljfong.freeshell.org/scalebar_after_map_redraw.png
I could use any suggestions here.
