Numeric Comparions in EXPRESSION Statements
James Card
jdcard at INREACH.COM
Fri Oct 20 22:55:56 EDT 2006
On Wed, 18 Oct 2006 17:54:45 -0700, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Did you try:
> EXPRESSION ([STATIONS] >= 2 AND [STATIONS] <= 10)
Thanks! That works exactly like I wanted it to.
I've added a note to the "Expressions in MapServer" HowTo at <URL:
http://mapserver.gis.umn.edu/docs/howto/msexpressions >:
Values inside quotation marks are treated as strings. When string
comparisons won't work -- for example, "EXPRESSION ('[SQFT]' >
'4000' AND '[SQFT]' <= '10000')" -- and you need to compare
numeric values, don't place quotation marks around the
[ATTRIBUTENAME] nor around the literal values to be compared.
This will provide a comparison of numeric values rather than
string values: "EXPRESSION ([SQFT] > 4000 AND [SQFT] <= 10000)".
It might be helpful to have something similar added to the Mapfile
Reference document.
James Card -- <URL: http://home.inreach.com/jdcard/ >
Often there are several ways to understand a given set of
facts; some of them may be more useful than others.
