PHP_Mapscript QueryByAttributes on PostGIS layer
Delfos, Jacob
Jacob.Delfos at MAUNSELL.COM
Tue Oct 24 04:12:36 EDT 2006
Hi All,
My QueryByAttributes PostGIS problem seems to be worse in version 4.10.
In 4.8.4, at least I could do:
$oLayer->queryByAttributes("roadname","roadname like 'EMERALD
RD'",MS_MULTIPLE); // must include SQL operators for query to work
But now, even that doesn't work anymore. It seems that it trips over the
single quotes around the value. Without the quotes, I can no longer
search on string values in a PostGIS table. What has been changed since
4.8?
My query does:
$gotResult = $oLayer->queryByAttributes("pglayer","name like 'new
layer'",MS_MULTIPLE);
My log says:
[24-Oct-2006 16:08:28] PHP Warning: [MapServer Error]:
prepare_database(): Error executing POSTGIS DECLARE (the actual query)
statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
"name"::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::t
ext from pgpoly WHERE (name like ) and (the_geom && setSRID(
'BOX3D(-149999998.5 -99999999,149999998.5
99999999)'::BOX3D,find_srid('','pgpoly','the_geom') ))' Postgresql
reports the error as 'ERROR: syntax error at or near ")" at character
148
I'd appreciate it if someone can help me figure this out. I did not see
any bugs in Bugzilla for this.
regards,
Jacob
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Delfos, Jacob
Sent: 19 September 2006 09:06
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] PHP_Mapscript QueryByAttributes
on PostGIS layer - bug or feature?
Hi List,
I'm trying to perform a QueryByAttributes operation on a PostGIS
layer, but I get an error. Basically, it seems that the where clause
being generated leaves out the attribute name and operator. Am I doing
something wrong?
My code is:
$gotResult = $oLayer->queryByAttributes("roadname","EMERALD
RD",MS_MULTIPLE);
My PHP error is:
[19-Sep-2006 08:53:34] PHP Warning: [MapServer Error]:
roadname::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),gid:
:text from roads WHERE (EMERALD RD) and (the_geom && setSRID(
99999999)'::BOX3D,find_srid('','roads','the_geom') ))' <br><br>
It works if I do:
RD'",MS_MULTIPLE);
Am I supposed to perform the QueryByAttributes operation
differently for different data sources? It gets more difficult if I
don't know in advance whether the type is text or number....
I searched the list and bugzilla for something similar, but
couldn't find it. I'm using php_mapscript 4.8.3 (I tried using
4.10beta2, but all my mapfiles get invalid map extent errors for some
reason).
Regards,
Jacob
JACOB DELFOS
GIS ANALYST
Maunsell Australia Pty Ltd
629 Newcastle Street, Leederville, WA 6007
PO Box 81, Leederville, WA 6902
Western Australia
ABN 20 093 846 925
Tel + 61 8 9281 6185
Fax + 61 8 9281 6297
jacob.delfos at maunsell.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061024/3ce559a3/attachment.html
