AW: Mapserver+Windows+ArcSDE
Mike Saunt
mikesaunt at GMAIL.COM
Wed Oct 25 03:41:45 EDT 2006
Hi
We've successfully connected through to SDE (with the help of Howard) and it
proves to be pretty simple. I am very happy with taking MS4W, extracting
our required installation files and then applying the relevant
libmap.dll(from the sub directory) when on site and then changing the
connection
strings. I'm very happy with this method as we don't need to recompile
(although we do for other reasons!)
Regards
Mike
On 25/10/06, Pleyer, Walter <Walter.Pleyer at lfrz.at> wrote:
> Hi Howard!
> > you get these errors. Are you trying to just render a layer?
> Yes, just simply rendering it is all we try to do.
> The backend DB is a Oracle 9.2.0.4 .
> > to build MapServer and all of its dependencies from scratch
> > on your platform of choice (Windows in your case). The time
> > and misery required to do that is at least an order of
> > magnitude larger than peeling apart the .\bin and .\cgi-bin
> > directories plus the SDE libmap.dll from the MS4W package.
> I'm aware of that.
> That's why I hoped that someone might have done that already.
> But this is certainly the lesser problem and more a matter of
> convinience.
> Walter
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061025/8abfbaa7/attachment.html
