freetype error for curved label
Yves Jacolin
yjacolin at FREE.FR
Fri Oct 27 04:40:27 EDT 2006
I just checked the GD version, and it is the 2.0.33 release :-/
Y.
Le Jeudi 26 Octobre 2006 20:20, Steve Lime a écrit :
> The follow support requires a newish version of GD that provided
> extended metrics from Freetype.
> We can't test in configure for that function, but we can test for
> another function that was added
> in that version. The relevant test when you watch for configure is
> looking for gdImageOpenPolygon.
> If that's found you have enough for path following labels.
> Basically you need gd 2.0.29+ but 2.0.33 is recommended.
> Steve
> >>> Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 10/26/2006 8:51:01 AM
> What does "/path/to/mapserv -v" report?
> -Steve W
> Yves Jacolin wrote:
> > Hi,
> > I am trying to build mapserver 4.10 to use curved label. When I use
> ANGLE
> > FOLLOW parameter in my mapfile I got this error :
> > "Mapserver error: Error in msDrawTextGD(): TrueType font support is
> not
> > available and is required for angled text rendering.
> > Error in msDrawTextGD(): TrueType font support is not available and
> is
> > required for angled text rendering."
> > But, I got freetype in mapserver config. No error message/warning. Do
> you know
> > where this problem come from ?
> > My mapfile config :
> > FONTSET fonts.txt
> > And fonst.txt :
> > Vera ./vera/Vera.ttf
> > VeraBd ./vera/VeraBd.ttf
> > Both url files are correct.
> > Regards,
> > Y.
Yves Jacolin
HBS-Research
51 rue de Verdun
92 158 Suresnes CEDEX
Tél. : 01 46 97 25 14
Fax : 01 46 97 20 10
Yves Jacolin
http://yjacolin.gloobe.org
