Using multiple .dbf files with the same .shp/.shx files
David William Bitner bitner at GYTTJA.ORG
Mon Oct 30 08:35:00 EST 2006
... or use filesystem symlinks to fake having two shapefiles
On 10/29/06, Gerry Creager <gerry.creager at tamu.edu> wrote:
> or, export the shapefile and its native dbf to postGIS, supplement the
> postGIS database, and then request what you need from the database...
> gerry
> Till Adams wrote:
> > Matt,
> > I guess it is difficult to do what you want. A shapefile is handled as
> one
> > file, although there are always three files.
> > Maybe it's possible for you to workaround with that JOIN Object in the
> > mapfile.
> http://mapserver.gis.umn.edu/docs/reference/mapfile/join/?searchterm=JOIN
> > Or you store the shapestuff in a database (or you create three shapes
> with
> > different namens and dbf-files). Then you may use the Variable
> > Substitution functionality from mapserver and pass the filename via the
> > url when requesting the map.
> > Till :-)
> >> Is there any way to use different .dbf files with the same .shp/.shx
> >> file in MapServer?  I'd like to make an online application that, based
> >> on some choices, would pull info from a different .dbf file, but use
> the
> >> same .shp/.shx file.  The different requests would have different .map
> >> files, but I don't see if there is any way to identify a different .dbf
> >> file to use other than the one of the same basename as the .shp/.shx
> >> files...
> >> Thanks,
> >> Matt
> Gerry Creager -- gerry.creager at tamu.edu
> Texas Mesonet -- AATLT, Texas A&M University
> Cell: 979.229.5301 Office: 979.458.4020  FAX 979.862.3983
> MAIL:  AATLT, 3139 TAMU
> Physical: 1700 Research Parkway, Suite 160,
> College Station, TX 77843-3139
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061030/d0ed2567/attachment.html
