[Fwd: Re: mapserv stdout png problem]
Hubert Asamer
hubert.asamer at UNIVIE.AC.AT
Mon Oct 30 17:54:08 EST 2006
Thanks Tamas- i will try it immediately!
Hubert
Tamas Szekeres wrote:
> I recall that the original proposal was:
> http://www.nabble.com/Proposing-to-support-for-creating-maps-with-mapserv.exe-using-the-command-line-p4976104.html
> As far as I remember against this proposal suppressing the header was
> the desired approach, however suppressing the header at all places
> like the OWS requests seemed to be a PITA.
> Tamas
> 2006/10/30, Hubert Asamer <hubert.asamer at univie.ac.at>:
>> ---------- Továbított levél ----------
>> From: Frank Warmerdam <warmerdam at pobox.com>
>> To: Hubert Asamer <hubert.asamer at univie.ac.at>
>> Date: Thu, 26 Oct 2006 15:55:24 -0400
>> Subject: Re: mapserv stdout png problem
>> Hubert Asamer wrote:
>> > Frank,
>> > one more question regarding the FW_Tools mapserv.exe:
>> > When i make a query like this: mapserv
>> "Query_string=map=.....&mode=map"
>> > i get a png with following header: Content-type: image/png
>> > Then i must remove the first two lines of the png file and i can
>> view my
>> > result-everthing ok!
>> > Do you know how to configure my query to avoid these two header lines?
>> Hubert,
>> There was some talk recently about adding a commandline switch to
>> mapserv
>> to supress this, but looking in the code it looks like nothing was done.
>> So, no, there is nothing that can be done.
>> My msautotest test suite has special python code to strip off these mime
>> types, and the WxS mapscript wrappers include a mechanism to strip off
>> the mime type. But I can't think of anything you can do when
>> invoking mapserv
>> at the commandline.
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | President OSGeo,
>> http://osgeo.org
>> __________ NOD32 1.1831 (20061024) Information __________
>> Diese E-Mail wurde vom NOD32 antivirus system geprüft
>> http://www.nod32.com
