PHP Mapscript and WMS Server
Nicol Hermann
mapserver at GEOWORLD.DE
Fri Sep 1 09:15:58 EDT 2006
Hi Frank,
thank you very much for the given example.
I tried your script and in general it works.
There a two things which are strange.
I tried the following REQUEST
http://localhost/~nicol/mapserver/dev/wxsGetMap.php?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=flurst&WIDTH=200&HEIGHT=200&FORMAT=image/gif&SRS=EPSG:31467&BBOX=3419615.22636,5523296.90857,3420494.15553,5524175.83774
The resulting image contains "bad lines" on the end.
Here is the output so that you can see what i mean.
http://geoworld.de/wxs/wxs_output_getmap.gif
The datasource of this layer is postgresql/postgis.
The second thing:
When i change the outputformat to png (image/png) the image is
completely broken.
Has this behaviour something to do with the first issue mentioned?
Do i miss something or is this a bug?
Many thanks for your help.
Nicol
Am Donnerstag, den 31.08.2006, 11:31 -0400 schrieb Frank Warmerdam:
> Nicol Hermann wrote:
> > Bart,
> > i there any working example how to use the GetMap Request with the new
> > MapScript wrappers for WxS Services?
> > I had no look so far using PHP Mapscript.
> > Any code snippets?
> > Many thanks
> > Nicol
> Nicol,
> I have confirmed that the WxS methods have been added to PHP MapScript for
> 4.10; however, I neglected to add any examples of it in the WxS howto.
> I've done a very very quick test with the following script which at least
> seems to parse properly. Could you try something like it and see if it works?
> <?php
> dl("php_mapscript.so");
> $req = ms_newowsrequestobj();
> $req->loadParams();
> $map = ms_newMapObj( "/u/www/maps/ukpoly/ukpoly.map" );
> $map->OWSDispatch( $req );
> If so, I'll update the howto with the example.
> Best regards,
