Postgis sequential scan and query performance
Paul Ramsey pramsey at REFRACTIONS.NET
Fri Sep 1 11:18:52 EDT 2006
Patrick,
That's great news!
Now, for real speed improvements, figure out how to draw a map that
does not require 100000 inputs :)  There is clearly some scale work
to be done, since most of those 1000000 inputs probably resolve to
little more than a couple pixels -- ie, most of their information is
being lost in the rasterization process, so is there a way to use
input with less information instead (lower resolution data...)
Paul
On 1-Sep-06, at 8:07 AM, P. S. Brannan wrote:
> I wanted to let you know that your suggestions worked. I pulled a
> bunch of sql statements out of the log and ran them in psql. The
> planner is now selecting the index for the critical query. This has
> resulted in average execution times of less than 3 seconds. That is
> a big improvement from 65 seconds. The entire map drawing process
> is now running in about 6 seconds. This compares to 120 seconds
> before the optimizations.
> I guess that the random_page_cost setting did the trick.
> Thanks for your help,
> Patrick
> Paul Ramsey wrote:
>> (Before I say anything, I am impressed with your care in
>> understanding issues of performance which have taken me years to
>> figure out!  Yes, compressing your tuples down to just the rows
>> you need will probably help a bit.)
>> Another thing to look at is that your PostgreSQL configuration
>> might be sub-optimal in a couple ways:
>> - Have you adjusted any postgresql.conf parameters at all?
>> - Let me assume you have a machine with 2Gb of RAM and are running
>> little on it besides PostgreSQL/PostGIS:
>> o Set your shared_buffers to 25000. (About 200M).
>> o Set your work_mem and maintenance_work_mem 8-16 times higher
>> than the defaults.
>> o Figure out how much memory you have allocated thus far, based on
>> some guesses regarding the number of concurrent users.
>> o From that, subtract as much memory as you think all other user
>> processes use.
>> o Set your effective_cache_size to the number you are now thinking of
>> o Change your random_page_cost to 2.  If you are a fiddler, adjust
>> it up and down until you get "good" results in index usage for a
>> number of use cases (small box, big box)
>> o  Turn autovacuum "on", just in case.
>> o If you are going to be doing a lot of mucking with tables,
>> consider changing some threshold values to you don't get
>> thrashing, the defaults are for a sort of continuous trickle of
>> change, and GIS people tend to change things in large batches.
>> (update table set foo=bar)
>> Hope this helps more.
>> Paul
>> On 30-Aug-06, at 7:45 PM, Patrick Brannan wrote:
>>> Paul,
>>> Well I re-read the PostGIS documentation - thank you very much -
>>> then I
>>> tried the following:
>>> gisdb=# SET enable_seqscan TO off;
>>> SET
>>> gisdb=# explain analyze SELECT
>>> cfcc::text,fename::text,asbinary(force_collection(force_2d
>>> (wkb_geometry)),'NDR'),ogc_fid::text
>>> from completechain WHERE wkb_geometry &&
>>> setSRID('BOX3D(-90.6004589271402 38.4732965951534,-89.9998214028184
>>> 38.8267482378407)'::BOX3D,find_srid
>>> ('','completechain','wkb_geometry') );
>>> QUERY
>>> PLAN
>>> Index Scan using idx_completechain_wkb_geometry on completechain
>>> (cost=0.00..364816.25 rows=90839 width=186) (actual
>>> time=37.049..12532.636 rows=103159 loops=1)
>>>   Index Cond: (wkb_geometry &&
>>> '0103000020FF7F0000010000000500000023AA47EB6DA656C0FABE9AFB943C43402
>>> 3AA47EB6DA656C095C6E1E2D269434089BCE812FD7F56C095C6E1E2D269434089BCE
>>> 812FD7F56C0FABE9AFB943C434023AA47EB6DA656C0FABE9AFB943C4340'::geomet
>>> ry)
>>> Total runtime: 12891.420 ms
>>> (3 rows)
>>> QUERY
>>> PLAN
>>> time=11.988..5204.924 rows=103159 loops=1)
>>> ry)
>>> Total runtime: 5497.049 ms
>>> (3 rows)
>>> QUERY
>>> PLAN
>>> time=0.088..1915.497
>>> ry)
>>> Total runtime: 2205.876 ms
>>> (3 rows)
>>> Not only was the first run 1/5 the time of the sequential scan
>>> run but
>>> the runs kept getting better. No matter how many I run with
>>> 'enable_seqscan' on the performance never improves. This must be
>>> something I don't understand about PostgreSQL caching.
>>> Notice that the cost estimate was actually higher on the first
>>> one, yet
>>> the performance was much better. I'm still working my way through
>>> this
>>> PostgreSQL stuff so maybe I'm missing something. But what I see
>>> leads me
>>> to believe that the planner didn't do a very good job on this
>>> one. This
>>> box covers the St. Louis metropolitan area in a database that is
>>> loaded
>>> with everything in Missouri and Illinois. So I've got to think that
>>> using an index would be better than looking at the whole table.
>>> Finally, you are right that my real concern is mapserver. It doesn't
>>> have to be lightning fast, but I would sure like to see it better
>>> than
>>> it is. And the reality is that I am only looking for major
>>> highways. So
>>> maybe there is a way to get mapserver to build a query that narrows
>>> things down before it starts doing the geometry stuff.
>>> I'm also thinking that PostgreSQL loads entire rows when it reads
>>> pages
>>> despite the fact that you may only want 1 or 2 columns. So
>>> refactoring
>>> the database might make a big difference in disk io. This is
>>> Tiger data
>>> and I only care about a small portion of it.
>>> The table row count, by the way, is 4,203,356. I'm very
>>> optimistic about
>>> the possible performance given the results. I just have to find a
>>> way to
>>> get mapserver to capitalize on it.
>>> Patrick
>>>> You are returning 103159 rows, which is a lot. Unless you have
>>>> 100million records in your table, sequence scanning will probably
>>>> work faster then index scanning, for retrieving that many rows.
>>>> Try a
>>>> bounding box that only encompasses a few hundred rows. You
>>>> should see
>>>> index scans turn on then.
>>>> By "query" performance, do you mean SQL query, or mapserver "query
>>>> mode". Because the latter has some quirks that need some care to
>>>> avoid.
>>>> P
>>>> On 30-Aug-06, at 1:00 PM, P. S. Brannan wrote:
>>>>> I just imported a bunch of tiger data into postgres. I am using
>>>>> mapserver as the frontend. Everything is working fine except for
>>>>> the performance. The query performance is terrible and I can't
>>>>> seem
>>>>> to get postgresql to use the index i created. Here's what's
>>>>> going on:
>>>>> Index Creation:
>>>>> create index idx_completechain_wkb_geometry on completechain using
>>>>> gist(wkb_geometry gist_geometry_ops);
>>>>> vacuum analyze;
>>>>> Vacuum Analyze:
>>>>> explain analyze SELECT cfcc::text,fename::text,asbinary
>>>>> (force_collection(force_2d(wkb_geometry)),'NDR'),ogc_fid::text
>>>>> from
>>>>> completechain
>>>>> WHERE wkb_geometry && setSRID('BOX3D(-90.6004589271402
>>>>>  QUERY PLAN
>>>>> Seq Scan on completechain  (cost=0.00..275502.54 rows=90839
>>>>> width=186) (actual time=10718.879..55686.238 rows=103159 loops=1)
>>>>>   Filter: (wkb_geometry &&
>>>>> 023A
>>>>> 812F
>>>>> D7F56C0FABE9AFB943C434023AA47EB6DA656C0FABE9AFB943C4340'::geometry
>>>>> Total runtime: 55973.870 ms
>>>>> (3 rows)
>>>>> Can anyone tell me what I need to do to get postgres to use the
>>>>> index? I'm sure that I'm missing something obvious.
>>>>> Thanks,
>>>>> Patrick Brannan
