converting from degrees to meters using cs2cs
Ryan Ollerenshaw ollerery at ENGR.ORST.EDU
Tue Sep 5 19:59:57 EDT 2006
I want to convert from longlat coordinates to lcc but i keep getting the
following error:
Given map extent is invalid. Check that it is in the form: minx, miny,
maxx, maxy
To get my new map extent i am using:
 >cs2cs    +proj=longlat +a=3396190 +rf=169.8944476026241 +lon_0=0
+no_defs
            +to
            +proj=lcc +a=3396190 +b=3396190 +units=m
-179 -89
-120680927.21   57506773.12 -19983.82
179 89
310182.75       6770294.70 -19983.82
i am then setting my extent to: -120680927.21 57506773.12 310182.75
6770294.70
what could i be doing wrong? and why does cs2cs return * when i use 180
or 90 as my input parameters?
I hope that was clear, that you for any help that you can provide.
-Ryan
