Using JOIN for querying
Fawcett, David
David.Fawcett at STATE.MN.US
Wed Sep 6 10:01:29 EDT 2006
Greg,
To me, the query is returning what I would expect from a database query.
Formatting the results as you want them seems more like a templating or
data formatting issue, not a query issue.
If you are using a javascript or custom interface, you should be able to
format the results the way that you want.
Does anyone who has done more with MapServer templates know how/if this
could be done with template magic?
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Greg Luker
Sent: Sunday, September 03, 2006 6:49 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Using JOIN for querying
Hi David,
(sorry for the long post)
David Fawcett said:
>I haven't been following this thread too closely, but are you sure that
>you want to use the unmaintained MyGIS option, or do you really want to
>use OGR with MySQL support enabled? I would go with OGR unless there
>is something in MyGIS that doesn't exist in OGR.
Thanks for your suggestions. I agree that I would be better off with OGR
- and I have:
LAYER
NAME "pts"
TYPE POINT
STATUS OFF
CONNECTIONTYPE OGR
CONNECTION '<OGRVRTDataSource>
<OGRVRTLayer name="exact">
<SrcDataSource>MYSQL:sites,user=user1,password=*****,host=11.109.9.10,po
rt=3
306,tables=feature;site</SrcDataSource>
<SrcSQL>SELECT site_id,
site_name,
site_easting_other,
site_northing_other,
feature_id,
feature_name
FROM site s
JOIN feature f ON s.site_id = f.feature_site_id
</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="site_easting_other"
y="site_northing_other"/>
</OGRVRTLayer>
</OGRVRTDataSource>'
DATA "exact"
TOLERANCE 5
PROJECTION
"proj=utm"
"south"
"zone=56"
END #projection
CLASS
NAME "Test Site - pts"
TEMPLATE "pquery.html"
SYMBOL "Dot"
SIZE 5
COLOR 0 0 255
END #class
HEADER "pquery_header.html"
FOOTER "pquery_footer.html"
END #layer
Using a map mode of nquery, the template pquery.html produces:
Site Name Feature
site1_name feature1_name
site1_name feature2_name
site1_name feature3_name
site2_name feature4_name
site2_name feature5_name
site3_name feature6_name
site3_name feature7_name
but what I want is:
site1_name
feature1_name
feature2_name
feature3_name
site2_name
feature4_name
feature5_name
site3_name
feature6_name
feature7_name
I can't seem to get this using OGR (I don't know the correct syntax) so
I thought I'd try to get what I wanted by using MyGIS because somebody
helped me with the syntax.
>Here is Frank's page for OGR/MySQL:
>http://ogr.maptools.org/drv_mysql.html
>Here is a description from Howard's blog:
>http://hobu.biz/index_html/mysql_ogr
Thankyou for these URLs. I have been to them both and, while they are
helpful, I still don't know the right OGR syntax for what I'm trying to
do. Could you help with the correct OGR syntax?
>Also, look at the HowTos, there are a few items on MySQL.
Could you please give a URL for these HowTos? I have Google-searched and
asked on this list for weeks, but unfortunately I have not solved my
"OGR/MySQL/query/multiple tables/join" question, though I have received
related help from several on this list (thanks).
Thanks,
Greg Luker.
