MapServer and World Files
Ryan Ollerenshaw ollerery at ENGR.ORST.EDU
Wed Sep 6 20:22:29 EDT 2006
I have two world files that are associated with two different .pngs that
should be very far apart, 50,000 meters according to the world files,
but MapServer is rendering them one just a few meters apart, does anyone
know why this might be?
World file 1:
4.553027622068700
0.000000000000000
0.000000000000000
-4.553027622068700
-2547.418954547465546
-107603.978306161036016
World file 2:
2.891044962554800
0.000000000000000
0.000000000000000
-2.891044962554800
-2976.330788950122496
-65781.391555490277824
Here is the pgrinfo command on the shapefile that was created, as you
can see the extent only covers a small area
 > ogrinfo -al -so moc_pds_test.shp
INFO: Open of `moc_pds_test.shp'
using driver `ESRI Shapefile' successful.
Layer name: moc_pds_test
Geometry: Polygon
Feature Count: 2
Extent: (-2977.776311, -124443.350966) - (2974.885266, -65779.946033)
Layer SRS WKT:
(unknown)
