ASCII and Shapefile
Greg Luker gluker at SCU.EDU.AU
Fri Sep 8 00:24:58 EDT 2006
Hi Ryan,
Ryan said:
> *Is there a way to go from an ASCII file to a Shapefile?  I have a file
> that contains a list of lat/long coordinates and there values at each
> point,  and i know what the projection will, be so is there a way to
> create a shapefile from and ASCII file if the projection is known?
If you have ArcGIS9.x:
Open the ASCII file in MS Excel, save it as a .csv, start ArcCatalog, Create
Feature Class from XY Table.
If you have ArcView 3.x:
Open the ASCII file in MS Excel, save it as a .csv, start ArcView, Add
Table, Create Event Theme.
I'm sure there are also other ways - maybe ogr?
Thanks,
Greg.
