make test for Java Mapscript fails [Mapserver 4.10.0 beta 3]
José Vilson de Mello de Farias vilson.farias at DIGITRO.COM.BR
Fri Sep 8 10:51:19 EDT 2006
Greetings,
  I've compiled the Mapserver 4.10.0 beta3 and Java Mapscript failed.
Has anyone else executed a "make test"? The error messages are bellow.
Should I register a new bug for this release or is it a problem that
only happens here?
  By the way, here is my QA/Tests Checklist :
Tester 	OS 	Build 	mapserv 	Py-Tests 	msautotest 	PHP 	Python 	Perl
Java 	CSharp 	utils 	GDAL 	OGR 	Postgis 	SDE 	OCI 	Ruby
vilsonfarias
	Linux 	p 	p
	  	  	 f
	p 	p
[root at dgtad java]# make test
javac -classpath ./:examples/:./mapscript.jar -d examples/
examples/ConnPool.java
examples/DrawMap.java
examples/DumpShp.java examples/MakePoint.java
examples/QueryByAttribute.java examples/ShapeInfo.java
exa                                     mples/WxSTest.java
examples/Metadata.java examples/RunTimeBuiltWMSClient.java
examples/RunTimeBuiltWMSClient.java:36: package MS_IMAGEMODE does not exist
           output.setImagemode(MS_IMAGEMODE.MS_IMAGEMODE_RGB.swigValue());
examples/RunTimeBuiltWMSClient.java:60: cannot find symbol
symbol  : variable MS_LAYER_TYPE
           layer.setType(MS_LAYER_TYPE.MS_LAYER_RASTER);
examples/RunTimeBuiltWMSClient.java:61: cannot find symbol
symbol  : variable MS_CONNECTION_TYPE
           layer.setConnectiontype(MS_CONNECTION_TYPE.MS_WMS);
3 errors
make: *** [test] Error 1
examples/ConnPool.java examples/DrawMap.java examples/DumpShp.java
examples/MakePoint.java examples/QueryByAttribute.java
examples/ShapeInfo.java examples/WxSTest.java examples/Metadata.java
3 errors
Best regards,
*José Vilson de Mello de Farias*
/Analista de Sistemas
//SSE - Segurança Pública/
*DÍGITRO TECNOLOGIA*
*E-mail:* vilson.farias at digitro.com.br
<mailto:vilson.farias at digitro.com.br%20>
*Messenger: *vilsonfarias at hotmail.com
*Fone:* (0xx48) 3281-7314
*Fax:* (0xx48) 3281-7000
*Site:* www.digitro.com.br <http://www.digitro.com.br%20>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060908/683b0f8a/attachment.html
