Transparency based on classification, possible?
Fawcett, David David.Fawcett at STATE.MN.US
Fri Sep 8 17:44:05 EDT 2006
No.
Transparency is set at the layer level.  Take a look at:
http://mapserver.gis.umn.edu/docs/reference/mapfile/layer
If you want to use URL variable substitution, you could probably change
the transparency of the LAYER on the fly, but not at the class level.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Hong
Sent: Friday, September 08, 2006 4:37 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Transparency based on classification,
possible?
Hello,
Is it possible to set the transparency of layer symbolization based on
the classification? Something similar to the effect of:
LAYER
	CLASS
		EXPRESSION "expr0"
		TRANSPARENCY 50
	END CLASS
	CLASS
		EXPRESSION "expr1"
		TRANSPARENCY 70
	END CLASS
END LAYER
Thanks.
