MapServer Capabilities
Ben Madin
ben at REMOTEINFORMATION.COM.AU
Sun Sep 10 20:35:52 EDT 2006
Keith,
We have done this using either of two methods below, where using
postgis was not an option.
to use MapServer directly, the quickest way is to generate the
mapfile to match the desired relationships. dynamically create a
mapfile (ie in php) to match the query (this is easiest if you load
the beginning and end of your standard mapfile, and just add the
appropriate layer / class details) and send the mapfile name back to
Mapserv.
Alternatively use mapscript to generate either the map image, or a
mapfile, and use this. Where there is a larger number of attributes
required over a larger area, regenerate the maps during the zoom to
show the increasing levels of detail. This is why we are using
mapscript now.
The main limitation to watch out for is when there are more than the
allowable number of layers or classes, but any map that is trying to
display more than this number of attributes is unlikely to mean much
to a reader, so think carefully about this as you develop your
initial queries.
good luck
Ben
Ben Madin
t/f: 08 9192 5535
m: 0448 887 220
ben at remoteinformation.com.au
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060911/1b4909d9/attachment.html
