problem plotting points on map using PHP/MapServer
Ben Sims benjaminsims at YAHOO.COM
Mon Sep 11 22:31:40 EDT 2006
Hi to all,
I'm trying out Mapserver, accessed through the PHP API running on my OSX dev machine. Specifically, I'm trying to draw a basic map, then plot some points on it, all done dynamically through the PHP script (ie without using a map file.
So far, I can draw the basic map with a country outline. However, I am unable to draw points on the map.
I have set up the basic map, and added a class and a layer for the points. I then run the following code:
$image=$map->draw();
$point = ms_newPointObj();
$point->setXY(-21.97, 64.15);
$return = $point->draw($map, $pointsLayer, $image, 0, 'A beautiful point');
$return is 0.
Is there any way I can get further information as to what might be going wrong here, with more detail than just the success/failure methods?
Couple of minor questions I would also appreciate advice on:
Apparently the PHP function ms_newMapObj() must have a map file passed to it, although I noticed that the Python version does not. Is there a reason for this? At the moment, I have a dummy map file containing nothing which I have to use.
If I use something like $layer->name = 'Layername', the layer name is not set (in fact it is set to null). Using $layer->set('name', 'Layername') it seems fine. Not really a problem, just wondered why.
Thanks to all for considering this - would very much appreciate it if you could point me in the right direction.
Regards,
Benjamin
