Mapfile Tuning
Eijnden, Bart van den (AGI) b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Sep 18 08:12:57 EDT 2006
I think Tamas mentioned an interesting idea a while ago to use binary MAP files. If your MAP file does not change that often, it could be a good way to speed things up in a production environment.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Pleyer, Walter
Verzonden: maandag 18 september 2006 13:23
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] Mapfile Tuning
Hi folks!
We are currently experiencing some performance troubles which we tracked
to the size of the mapfile.
We expect the mapfile to grow to well over 100 layers and analysis shows
that the parsing of this mapfile slows the mapgeneration down by almost
a second each time.
Is there enaything else, apart from using mapscript, that can be done to
tweak the performance?
Walter
LFRZ
A-1200 Wien, Dresdner Strasse 89
Tel:   ++43(1)33 176/421
Fax:   ++43(1)33 176/999
Mobil: 0676/5256642
Email: walter.pleyer at lfrz.at
WWW:   http://www.lfrz.at
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
