Mapfile Tuning
Eijnden, Bart van den (AGI)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Sep 18 09:52:30 EDT 2006
That's absolutely true. And it is read a few times for a map request .....
Alternatively, you can strip all unused entries from your epsg file. That's the approach we take here.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Daniel Morissette
Verzonden: maandag 18 september 2006 15:47
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] Mapfile Tuning
Do you use "init=epsg:xxxx" type of projection definitions in your
layers? In the past I have found the EPSG codes lookup to be quite
expensive. If you use that then you may find that using native proj4
definitions for your projections might help.
Daniel
Pleyer, Walter wrote:
> Hi folks!
> We are currently experiencing some performance troubles which we tracked
> to the size of the mapfile.
> We expect the mapfile to grow to well over 100 layers and analysis shows
> that the parsing of this mapfile slows the mapgeneration down by almost
> a second each time.
> Is there enaything else, apart from using mapscript, that can be done to
> tweak the performance?
> Walter
> LFRZ
> A-1200 Wien, Dresdner Strasse 89
> Tel: ++43(1)33 176/421
> Fax: ++43(1)33 176/999
> Mobil: 0676/5256642
> Email: walter.pleyer at lfrz.at
> WWW: http://www.lfrz.at
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
