Mapfile Tuning
John Cole john.cole at UAI.COM
Mon Sep 18 10:39:49 EDT 2006
Do you have to remove the extra projections or is it good enough to move the
ones you use to the front of the file?
Thanks,
John Cole
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Fawcett, David
Sent: Monday, September 18, 2006 9:04 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Mapfile Tuning
This sounds like a great start to a 'Mapfile Tuning' HowTo...
Behalf Of Eijnden, Bart van den (AGI)
Sent: Monday, September 18, 2006 8:53 AM
That's absolutely true. And it is read a few times for a map request
Alternatively, you can strip all unused entries from your epsg file.
That's the approach we take here.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Daniel Morissette
Verzonden: maandag 18 september 2006 15:47
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] Mapfile Tuning
Do you use "init=epsg:xxxx" type of projection definitions in your
layers? In the past I have found the EPSG codes lookup to be quite
expensive. If you use that then you may find that using native proj4
definitions for your projections might help.
Daniel
Pleyer, Walter wrote:
> Hi folks!
> We are currently experiencing some performance troubles which we
> tracked to the size of the mapfile. We expect the mapfile to grow to
> well over 100 layers and analysis shows that the parsing of this
> mapfile slows the mapgeneration down by almost a second each time.
> Is there enaything else, apart from using mapscript, that can be done
to
> tweak the performance?
> Walter
> LFRZ
> A-1200 Wien, Dresdner Strasse 89
> Tel:   ++43(1)33 176/421
> Fax:   ++43(1)33 176/999
> Mobil: 0676/5256642
> Email: walter.pleyer at lfrz.at
> WWW:   http://www.lfrz.at
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations. This
message is intended solely for the addressee. If you have received this
message in error, please delete it and notify the sender immediately.
When in doubt whether this message is correct or complete, please
contact the sender.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
