Mapserver install
Ryan Ollerenshaw ollerery at ENGR.ORST.EDU
Mon Sep 18 17:07:16 EDT 2006
The Error that i am getting:
*Warning*: dl() [function.dl <http://neuron/mapserver/function.dl>]:
(null): Unable to initialize module Module compiled with module
API=20050922, debug=0, thread-safety=0 PHP compiled with module
API=20020429, debug=0, thread-safety=0 These options need to match in
*/var/www/htdocs/mapserver/phpinfo_mapscript.phtml* on line *21
*this occures when i try to call dl('php_mapscript.so')*
Here is the configure that i am using:
./configure --with-proj=/usr/local/  --enable-runpath
--with-geos=/usr/local/bin/geos-config
--with-ogr=/root/FWTools-1.0.5/bin/gdal-config
--with-gdal=/root/FWTools-1.0.5/bin/gdal-config
--with-postgis=/usr/local/pgsql/bin/pg_config
--with-curl-config=/usr/bin/curl-config
--with-php=/usr/local/include/php  --with-wcs --with-wfs
--with-wmsclient --with-wfsclient --with-threads
I then
    make mapscript/php3/php_mapscript
    cp mapserv /var/www/cgi-bin/
    cp mapscript/php3/php_mapscript.so /path/to/php/extenstion/directory
Any idea on what i could be missing? or how i can better find out what
the problem is?
