How can Create OVF file (for OGR MYSQL connection)
interactively
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Tue Sep 19 11:37:25 EDT 2006
David,
my guess without studying the code is that this does not make a
difference in performance.
I think a Mapserver EXPRESSION will make it into the SQL that OGR passes
to MySQL in the end. I don't believe Mapserver does the filtering itself
on the whole dataset.
Best regards,
Bart
Fawcett, David schreef:
> Bart,
> I am assuming that this method would be faster than requesting the whole
> table from MySQL and then using variable substitution to set an
> expression for a class that displays only the record of interest.
> I know that it would be faster to only pass the data that is needed, I
> am more curious about whether the OGR/MySQL query mechanism is better or
> worse than 'filtering' with a mapfile expression.
> David.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Bart van den Eijnden (OSGIS)
> Sent: Tuesday, September 19, 2006 2:31 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] How can Create OVF file (for OGR
> MYSQL connection) interactively
> See:
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData
> Section: Dynamic Control of Virtual Sources
> Best regards,
> Bart
>> Dear friends;
>> Finally I have solved to read point data form mysql database than
>> draw map by using those data.
>> I have created Peak Ground Acceleration (PGA) map for the specified
>> earthquake which data are
>> stored in MySql. But I would like to display map for all earthquake
> which
>> are
>> described in the Mysql table as eq-id column.I mean PGA data are
> stored
>> in mysql database.table for several earthquakes
>> and one of the column is called EQ_ID which use for the seperate PGA
> data
>> from other earthquake like
>> EQ_ID Lon Lat PGA
>> 200006060242 30.40 32.45 2.5
>> 200006060242 30.41 32.46 2.6
>> 200006060242 30.42 32.47 2.7
>> 200606071708 38.45 40.98 5.6
>> 200606071708 38.46 40.99 5.7
>> 200606071708 38.47 41.00 5.7
>> 200606071708 38.48 41.01 5.8
>> I have querid mysql database by using ovf file as following
>> <OGRVRTDataSource>
>> <OGRVRTLayer name="acceleration">
> <SrcDataSource>MYSQL:database,user=user,password=pass_wd,host=100.00.00.
> 21,port=3306,tables=d_pgadata1</SrcDataSource>
>> <SrcSQL>SELECT eq_id,latitude,longitude,acceleration from d_pgadata1
>> where eq_id like '%200006060242%' </SrcSQL>
>> <GeometryType>wkbPoint</GeometryType>
>> <GeometryField encoding="PointFromColumns" x="longitude"
> y="latitude"/>
>> </OGRVRTLayer>
>> </OGRVRTDataSource>
>> As you see when I create map by layer OGR this will just the eq_id
>> like '%200006060242%'. But I would like to change this eq_id by
>> interactively for example who will
>> like to see 200606071708 earthquake PGA map he/she can change sql
>> statement in
>> ovf file by using php or html commands from web...
>> Do you have any idea is it possible or not.
>> Please I wellcome any kind of information about it..
>> Thank you
>> Murat
>> This message has been scanned for viruses and
>> dangerous content by MailScanner, and is
>> believed to be clean.
OSGIS, Open Source GIS
http://www.osgis.nl
