Mapfile Tuning
Daniel Morissette dmorissette at MAPGEARS.COM
Tue Sep 19 11:56:02 EDT 2006
Frank Warmerdam wrote:
> I was thinking primarily of PROJECTION blocks with an "init=" clause.  I
> haven't traced through to see if WMS advertising of epsg projections
> triggers a lookup.  I presume not, but that is just a presumption.
Last time I worked on that code there was no lookup for projections
advertized via the wms_srs metadata, only for projections defined in the
PROJECTION block using epsg codes.
Daniel
