WMS and C# Mapscript
Todd Fagin tfagin at COORDINATESOLUTIONS.COM
Fri Sep 22 12:12:30 EDT 2006
The answer to your question is yes, it works in CGI MapServer, but not C#
MapServer.  We have tracked the problem down to the location of the Proj
library files and are currently attempting to work through it.
Thanks,
Todd Fagin
Coordinate Solutions, Inc.
501 N.E. 15th St.
Oklahoma City, OK 73104
405.246.9396 (Voice)
405.227.0781 (Fax)
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Tamas Szekeres
Sent: Friday, September 22, 2006 11:04 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WMS and C# Mapscript
Did you mean that the same mapfile works with the mapserv application,
but not works when loading into a mapObj using mapscript?
Tamas
2006/9/22, Todd Fagin <tfagin at coordinatesolutions.com>:
> Greetings list,
> We are using the following to access data from a WMS.  It works fine in a
> straight map file, but does not work with a C# mapscript. The error
message
> simply states "System.ApplicationException was unhandled. Message="No such
> file or directory". Source="mapscript_csharp""
> Any suggestions would be greatly appreciated.
>       LAYER
>             NAME "wms_2003"
>             GROUP "Imagery"
>             TYPE RASTER
>             STATUS ON
>             CONNECTION
> "http://maps.scigis.com/wmsconnector/com.esri.wms.Esrimap/WMS_COLOR_DOQQ?"
>             CONNECTIONTYPE WMS
>             TRANSPARENCY 60
>             METADATA
>                   "wms_srs" "EPSG:102003"
>                   "wms_name" "1"
>                   "wms_server_version" "1.1.1"
>                   "wms_format" "image/png"
>                   "wms_title" "2003 Aerial Photos"
>                   "NoID" "T"
>                   legend_order "4"
>             END
>       END
> Todd Fagin
> 501 N.E. 15th St.
> 405.227.0781 (Fax)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060922/fc456f0a/attachment.html
