HTML Legend.
Bob Basques bob.b at GRITECHNOLOGIES.COM
Fri Sep 22 21:48:56 EDT 2006
All,
Hi all, I've been using the HTML legend for a while now with very good
results, I have a check box system working nicely showing when a layer
is on/off, etc.
I was wondering, has anyone an example of setting it up to grey out a
checkbox if the scale of view is out of range (MINSCALE/MAXSCALE in the
mapfile).  I have an idea of how it might be done, but not sure.  Just
asking before I go at it from scratch.
Here is my Legend TEMPLATE as it stands now along with a typical MAPFILE
entry, and a sample output on the end:
MAPFILE ENTRY (one of many :c):
    METADATA
          LEGEND_TITLE "Census Tract Centroids"
          LEGEND_META_GROUP "foreground"
          LEGEND_DISPLAY_LEVEL "1"
    END
LEGEND TEMPLATE:
    [leg_header_html]
    [/leg_header_html]
    [leg_group_html]
    [if name=first_foreground_layer oper=isset] <b>Foreground:</b> <br
    /> [/if]
    [if name=first_background_layer oper=isset] <b>Background:</b> <br
    /> [/if]
    [if name=legend_display_level oper=isset]
    [if name=legend_display_level oper=neq value=-1]
    [if name=layer_status oper=neq value=2]
    <input alt="[leg_group_name] Control"
    [if name=legend_meta_group oper=eq value=foreground] type="checkbox"
    [/if]
    [if name=legend_meta_group oper=eq value=background] type="radio" [/if]
    name="layer" value="[leg_group_name]"
    [if name=layer_status oper=neq value=0] checked="checked" [/if] />
    [if name=group_maxscale oper=isset]
    <input type="hidden" name="[leg_group_name]_Maxscale"
    value="[metadata name=group_maxscale]" />
    [/if]
    [if name=group_minscale oper=isset]
    <input type="hidden" name="[leg_group_name]_Minscale"
    value="[metadata name=group_minscale]" />
    [/if]
    <img alt="[leg_group_name] Legend Image"
    name="[leg_group_name]LegendImg" src="[leg_icon]" width="21"
    height="14" />
    [/if]
    [if name=metadata_url oper=isset]
    <a href='javascript:var temp = window.open("[metadata
    name=METADATA_URL]", "meta",
    "resizable,scrollbars,location,toolbar,height=300,width=500")'>
    [/if]
    [if name=legend_title oper=isset]
    [metadata name=LEGEND_TITLE]
    [/if]
    </a>
    [/if]
    <br />
    [/if]
    [/if]
    [/leg_group_html]
    [leg_layer_html opt_flag=0]
    [if name=legend_display_level oper=eq value=2]
    <img alt="Group Legend Image" src="[leg_icon]" width="21"
    height="14" /><br /><span class="small">[leg_layer_name]</span><br />
    [/if]
    [/if]
    [/leg_layer_html]
    [leg_class_html opt_flag=0]
    [if name=legend_display_level oper=eq value=3]
    <img alt="Class Legend Image" src="[leg_icon]" width="21"
    height="14" /><br /><span class="small">[leg_class_name]</span><br />
    [/if]
    [/if]
    [/leg_class_html]
    [leg_footer_html]
    [/leg_footer_html]
OUTPUT:
    <input alt="bg_mntrct00_point Control"
    type="checkbox" name="layer" value="bg_mntrct00_point" />
    <img alt="bg_mntrct00_point Legend Image" name="bg_mntrct00_pointLegendImg" src="/tmp/view_27723_1158975512_22_0_20_12.png" width="21" height="14" />
    <br />
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060922/d5158991/attachment.html
