Image PROJECTION
Frederico Lucca fredlucca at GMAIL.COM
Mon Sep 25 12:28:28 EDT 2006
Hello list,
Which parameters must I pass to PROJECTION to see the image below correctly?
My mapfile is latlong WGS84.
I'm trying
"proj=latlong"
"ellps=intl"
"zone=23"
"units=m"
"south"
"no_defs"
without success.
Driver: ECW/ERMapper Compressed Wavelets
Size is 8151, 4202
Coordinate System is:
GEOGCS["CORREGO ALEGRE",
    DATUM["CORRALEG",
        SPHEROID["INT24",6378388,297]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433]]
Origin = (-46.807828,-23.896465)
Pixel Size = (0.00000491,-0.00000451)
Corner Coordinates:
Upper Left  ( -46.8078275, -23.8964648) ( 46d48'28.18"W, 23d53'47.27"S)
Lower Left  ( -46.8078275, -23.9154343) ( 46d48'28.18"W, 23d54'55.56"S)
Upper Right ( -46.7678042, -23.8964648) ( 46d46'4.10"W, 23d53'47.27"S)
Lower Right ( -46.7678042, -23.9154343) ( 46d46'4.10"W, 23d54'55.56"S)
Center      ( -46.7878158, -23.9059496) ( 46d47'16.14"W, 23d54'21.42"S)
Band 1 Block=8151x1 Type=Byte, ColorInterp=Red
  Overviews: arbitrary
Band 2 Block=8151x1 Type=Byte, ColorInterp=Green
Band 3 Block=8151x1 Type=Byte, ColorInterp=Blue
Thanks in advance,
Fred
"Everything under the sun is in tune
But the sun is eclipsed by the moon"
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060925/2aaa2eb8/attachment.html
