adding label to point layer in PHPMapscript
Delfos, Jacob Jacob.Delfos at MAUNSELL.COM
Tue Sep 26 04:04:33 EDT 2006
Murat,
Are you sure you want all your villages to have the same label
($villagename)?
I think you may want to define a labelitem:
$point_layer->set("labelitem","villagename"); // "villagename" is the
name of the attribute of the layer
Also, you quoted "$koyadi", which is probably not correct. Or remove the
Have you tested whether any part of this code works? Which part is
giving you trouble? Does your PHP log say anything?
regards,
Jacob
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Murat BEYHAN
	Sent: 26 September 2006 15:56
	To: MAPSERVER-USERS at LISTS.UMN.EDU
	Subject: [UMN_MAPSERVER-USERS] adding label to point layer in
PHPMapscript
	Dear Friends,
	I'have draw point layer by using php. That point only one in the
map.
	Now I would like to make label for that point as $villagename
	I have tried following codes but I think something wrong.
	Could you help me What is my mistake...
	Regards
	Murat
	$villagename='kanamura';
	 $map_path="/var/www/html/zone/";
	 $map = ms_newMapObj($map_path."zone.map");
	 $map->setExtent($nMinX, $nMinY, $nMaxX, $nMaxY);
	// create a temp layer to hold our points
	$point_layer = ms_newLayerObj($map);
	$point_layer->set("name", "$koyadi");
	$point_layer->set("type", MS_LAYER_POINT);
	$point_layer->set("status", MS_DEFAULT);
	$point_layer->setProjection("proj=latlong",MS_TRUE);
	// create a class and style for this layer
	$point_class = ms_newClassObj($point_layer);
	$point_style = ms_newStyleObj($point_class);
	$point_symbol = $map->getSymbolByName("cpoint");
	$point_style->set("symbol", $point_symbol);
	$point_style->set("size", 12);
	$point_style->color->setRGB(255,0,255);
	$point_style->outlinecolor->setRGB(255,255,0);
	$label = $point_class->label;
	$label->set("position", MS_CC);
	$label->set("font","sans");
	$label->set("type",MS_TRUEYPE);
	$label->set("size",MS_MEDIUM);
	$label->color->setRGB(22,8,3);
	$label->backgroundcolor->setRGB(0,0,0);
	$label->set(minsize,4);
	$label->set(maxsize,100000);
	// draw our image without the points
	 $ref = $map->drawreferencemap();
	 $legend=$map->drawLegend();
	$image = $map->draw();
	// initialize our point and add it to the map
	$point = ms_newPointObj();
	$longitude=$lon;// comes from select queries from mysql as a
result
	$latitude=$lat;// comes from select queries from mysql as a
result
	$point->setXY($longitude, $latitude);
	$point->draw($map, $point_layer, $image, 0, "");
	  $map_url=$image->saveWebImage();
	  $ref_url = $ref->saveWebImage();
	  $legend_url=$legend->saveWebImage();
	This message has been scanned for viruses and
	dangerous content by MailScanner <http://www.mailscanner.info/>
, and is
	believed to be clean.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060926/6344e26f/attachment.html
