Encoding problem with curved labels
Volkan Ulukut vulukut at TESCILTURK.COM
Tue Sep 26 08:08:47 EDT 2006
Till,
Thanks for the suggestion but I'm already using ENCODING in my label
definition. Here is the code for the label in my map file:
     LABEL
        TYPE TRUETYPE
        FONT "fritqat"
        SIZE 7
        MINSIZE 4
        MAXSIZE 256
        POSITION cc
        OFFSET 0 0
        ANGLE FOLLOW
        BUFFER 10
        #MINDISTANCE -1
        MINFEATURESIZE -1
        COLOR 0 0 0
        OUTLINECOLOR 254 254 254
        ANTIALIAS TRUE
        PARTIALS FALSE
        FORCE FALSE
	  ENCODING "ISO-8859-9"
     END
Note that this is not just an encoding problem, other then the curved labels
all labels are correctly encoded, the problem is only with curved ones.
-----Original Message-----
Sent: Tuesday, September 26, 2006 2:32 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Encoding problem with curved labels
Volkan,
might be you should use the "ENCODING" keyword for your label
-> http://mapserver.gis.umn.edu/docs/reference/mapfile/label
Just an idea, I never worked with that on my own.
Till
Volkan Ulukut schrieb:
> Hi List,
> I've been struggling with curved label support of mapserver. First I
> thought i got it working correctly but then i realised some of the
> labels got encoding glitches on them. Specifically the ones that need
> to be curved and have special characters, as you can see on the
> attachment. I'm assuming this is a bug. Anyone else came across this
> one and solved? Since curved labels are new, i couldn't find anything
> about this bug with googling.
*     www.webmapcenter.de - Hosting	*
*       GDIdevL 'Start GDI from CD'      		*
*         http://www.terrestris.de          	*
Dipl. Geogr. Till Adams
terrestris, H. Paulsen& T. Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * http://www.terrestris.de
